Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-26-2012, 07:50 PM   #1
Jrzvetteman
Junior Member
Default 1986 clutch issue
I recently purchased a 86 z51 coupe. The clutch pedal is stuck to the floor and I mean its so stuck I can't even pull it up by hand. I have plenty of mechanical experience just limited clutch experience. Would anyone know where to begin on servicing this issue. Any help would be greatly appreciated.
Jrzvetteman is offline   Reply With Quote
Old 12-26-2012, 07:57 PM   #2
ghoastrider1
CF Senior Member
ghoastrider1's Avatar
i have only incountered this in older cars..i'm talking 60s here. On those, it was the pressure plate. With these clutch slave cylinders and what not..lets wait for someone that has a "modern" vette for input.
ghoastrider1 is offline   Reply With Quote
Old 12-26-2012, 08:22 PM   #3
danno85
CF Senior Member
Well, mechanically the clutch pedal hinges on a bolt through a bracket up under the dash, although doesn't seem likely that would have seized. The pedal is also physically connected to a rod that goes into the clutch master cylinder (next to the power brake booster). I would suspect a problem with the clutch master cylinder, like the piston/plunger assembly being frozen or seized.
danno85 is offline   Reply With Quote
Old 12-26-2012, 08:56 PM   #4
black88z51
CF Senior Member
black88z51's Avatar
is there still fluid in the system?
black88z51 is offline   Reply With Quote
Old 12-27-2012, 08:38 AM   #5
AGENT 86
CF Senior Member
AGENT 86's Avatar
Quote:
AGENT 86 is offline   Reply With Quote
Old 12-30-2012, 11:53 PM   #6
Ziggy91
CF Senior Member
Ziggy91's Avatar
Slave cylinder also has a plunger type assembly in it, like the clutch master. If either are stuck, the clutch is going nowhere. Then again, I've also heard of this same issue about the flywheel being a possible.
Ziggy91 is offline   Reply With Quote
Reload this Page 1986 clutch issue
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
