How To Repair your Range, Miles, etc, button assy
c4 information center 87 vette soft top manual tranny
hello vette people iam having an issue with this ,my voltage,fuel reading ,rpm, and speed are not showing on this center,only recently, started the cluster is showing temp, and 0il pres and temp but everything else is lite up it seems sudden this toke place, I had alternator problems and fixed , ground issue, is there another fuse for these specifically behind this led ,in the hanes edition I can see a 10 fuse beside the flasher, is that the posibles issue maybe, it seems unlikely that if the blubs for my problem are burnt out ,,only any suggestion my email is danomano1@hotmail.com hello from newfoundland , Canada
2nd Gear
if you need to replace the bulbs for that i found them here worked great
http://www.autolumination.com/74.htm
My fuel reset and trip reset bulb works. I would like to replace it as well while I have the DIC out. Anyone know where to find it and the part number for it, as well? The casing on the original bulb is silver. The dash looks just looks really cool when everything is lit up. Thanks
lol Yeah......don't do that. I've seen some serious idiots posting what they did to their poor vettes some time back. NOS bottles + old worn out stock valves, pistons and rings = recipe for engine disaster. They were also blowin out trannies like they were goin out of style.
OR radio button issues
[QUOTE=Spharticus;1582661966]I had problems with this button assy. I couldn’t reset my oil change light, and some of the buttons ceased to function,
LOOK..Have you ever tried tuner cleaner ?
Now this is not always a foreshore fix, but has worked in the past on many of jobs and only takes A 3 SECOND BURST, a good can of electric contact cleaner, tuner cleaner or electric motor cleaner. WARNING do a test on plastic before you use it !!! there not all the same !!
OK case in point, the last one i did.. my fish'n budy came up to me with a new radio in hand on a sunday morn.. can you install this for me .. buddy ?
NO but for $20 bucks I can fix the one you have !.. now this is funny .. as i whent and got my can of tuner cleaner and with a 3 second spray , just ovr the front of the radio " i said that will be 20 bucks " he tried it and it worked perfect ! he insisted on paying me and took the new radio back for return. I graciously took the twenty dollars from him as he was in shock and awe. that's old school baby !
as the pool pump motor repair guy in Florida say's ... knowlage is the only thing you can take with you when you die, SO SPREAD IT AROUND !
LIKE ME FALLOW ME, TELL ME IF IT WORKED FOR YOU ?
did this last night and it worked great, your information is perfectly written. i replaced the bulbs in mine years ago with 12V bulbs from radio shack.
thank you!!
thank you!!
By any chance do you remember what fuse number is associated with the Trip Monitor unit? All of my lights went out, so I assume it is a fuse; however, I do not see anything in the fuse box labels that seem to represent the Trip Monitor unit.
thx
kc
thx
kc
