Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-18-2012, 04:47 PM   #1
garyc4
Junior Member
Default L83/L98 head swap
New to the forum, I assume this questions's been covered before, but didn't get the info I ws looking for with a search.
Considering swapping my stock iron heads on the 84 L83 with L98 aluminum heads from a 1988 L98 I've got access to. 2 questions:
(1) Are the center bolt holes in the 88 heads compatible with the earlier 84 manifold? I know they switched at some point, but not sure when.
(2) Knowing the swap of 78cc to 58cc will raise compression to near 11:1 on my L83, does anyone have experience or knowlege of using thicker head gaskets to mitigate some of the compression rise?
Thanks, many more questions to come. BTW, If there is a specific forum more focused on the 82/84CFI, please let me know.
garyc4 is offline   Reply With Quote
Old 12-18-2012, 04:50 PM   #2
garyc4
Junior Member
I'm referring to the intake manifold center bolt holes, sorry
Old 12-18-2012, 05:24 PM   #3
ghoastrider1
CF Senior Member
ghoastrider1's Avatar
not sure about the intake but arnt the 88 heads center bolt valve covers?
ghoastrider1 is offline   Reply With Quote
Old 12-18-2012, 07:25 PM   #4
wilcar
CF Senior Member
I believe the 86 aluminum heads have the same bolt pattern as your crossfire intake but the 87 and up heads had the different bolt pattern and center bolt valve covers. On my 84 I got rid of the factory 624 heads and bought some Summit cast iron 152123 large valve heads(made by Dart) for $630. They are 72 cc heads with .525 lift springs, screw in studs and modern fast burn angle plug design. Even with the aluminum heads you want to use the restrictive intake ports of the crossfire intake will impede any meaningful performance increase. I went with a carb conversion , a more agressive camshaft, true dual exhaust with no cat and the Summit heads and am very happy with the large power increase. Maybe you can get the whole 88 TPI set up along with the heads.
wilcar is offline   Reply With Quote
Old 12-18-2012, 08:07 PM   #5
powerpigz-51
CF Senior Member
powerpigz-51's Avatar
Most people do not realize that the iron 624 heads actually flow more than 113 heads. The weight savings might be worth half a tenth in the quarter. So not worth it. The 113's take to porting much easier (but expensive), if further mods are in the future. I am sure a few peeps have tried running 113's and flat top pistons, but it sounds like too much compression to me. Better off throwing some thin gaskets on the 624's.
powerpigz-51 is offline   Reply With Quote
Old 12-19-2012, 12:35 AM   #6
84wannabezo6
CF Senior Member
Support Corvetteforum!
84wannabezo6's Avatar
The head gaskets on the 84 l83 are about as thin as you can get 015 steel shim
84wannabezo6 is offline   Reply With Quote
Old 12-19-2012, 12:41 AM   #7
84wannabezo6
CF Senior Member
Im trying the renegade intake with the edelbrock performer heads. I really think you have to research all the things you want to do before you plunk down the bucks. The 113 heads and the 624 heads have the same intake manifold bolt pattern the center ones go straight in at the same angle as the outside ones
Old 12-19-2012, 01:42 PM   #8
garyc4
Junior Member
Quote:
Thanks, appreciate the info. I have an x-ram purchased years ago and never used, and a spare CFI manifold avail for porting. Between those two options which will cost me nothing, and the renegade which I understand may be the best, but most expensive for me, I will need to make a chioce. My goals are not crazy. 300 hp woud be fine. The 88 heads I refer to are acutallly part of a complete L98 that I have, and may rebuild if it seems I can get what I want at a reasonable investment.
What are you doing with your throttle bodies if I may ask?
Old 12-19-2012, 03:18 PM   #9
powerpigz-51
CF Senior Member
Yes, and if he goes this route, he needs to make sure that he doesn't use the typical replacement felpro, which is .039. Those Summit iron heads that Wilcar has on his, would be perfect for this build IMO. I believe member "Coupeguy" had some 113's on top of some flat top pistons, I believe he may have used 2 gaskets? It's been awhile.
Old 12-19-2012, 04:58 PM   #10
wilcar
CF Senior Member
The 624 thin cast heads are very prone to cracking on the exhaust valves near the heat crossover and most tech forums and Chevy high performance books state that the 624 heads are the worst of the worst heads to use and are not worth sinking any money into for a performance application. Maybe that is why I have not had one bite on my 624's for $99 on craigstist!!!!! One mechanic stated that out of 10 sets of 624's you might get one pair that is not cracked.
Old 12-20-2012, 10:48 AM   #11
ejscarfo
CF Senior Member
ejscarfo's Avatar
Send a message via AIM to ejscarfo
Quote:
Are the 624's the same heads on the 85 L98's or are those different?
ejscarfo is offline   Reply With Quote
Old 12-20-2012, 11:04 AM   #12
rklessdriver
CF Senior Member
rklessdriver's Avatar
Quote:
You should just use the entire L98 engine and put your X Ram or ported CFI intake on it.
The factory hyd roller cam is reason enough.
Will
rklessdriver is offline   Reply With Quote
Old 12-20-2012, 11:49 AM   #13
garyc4
Junior Member
Quote:
That is new to me. Are the flow characteristics of these two heads documented? I had been under the impression from past reading that the alummnum D-port heads had better flow than the earlier iron corvette C4 heads, and that the 88 year heads were among the best. Thoughts?
Old 12-20-2012, 12:09 PM   #14
Tom400CFI
CF Senior Member
Tom400CFI's Avatar
1. Only on F-bodies and other models. On CORVETTES, the center intake bolts are still angled as they have been since '55.
2. No. It does work though. Check your push-rod length with the new gaskets.
Tom400CFI is offline   Reply With Quote
Old 12-20-2012, 12:39 PM   #15
ghoastrider1
CF Senior Member
its my understanding that the 113 heads do NOT flow much more than the old iron heads or even the old fuelie heads. They are better because of the swirl port chambers and intake port velocity, working the exhaust ports give good results on these heads. they are 22 pounds lighter...062 vortec heads are much better...said to be the best heads Chevy ever made .
Old 12-20-2012, 12:44 PM   #16
mcm95403
CF Senior Member
mcm95403's Avatar
Send a message via Yahoo to mcm95403
I would seriously consider the GM Fast Burn heads. I just installed a set on my 91 and am very happy with them. The only problem I ran into with them is that they DO NOT accept center bolt valve covers. The shape of the gasket rail doesn't match up to the centerbolt pattern. You may also need to have your intake ports welded up to cover the taller port, but look carefull - the floor of the ports also had a mismatch.
__________________
www.dunritenetworks.com
previous Vettes: 84 CFI auto, 99 Nassau Blue 6-speed
current Vette is a Turquoise Metallic 91 automatic, 3.07's, Fast Burn heads, SD LT-4 cam, Bosch III's, Accel Super Ram & 58MM TB, LT-1 manifolds, Magnflow catted Y, Flowmaster direct replacement mufflers, 1984 Z51 springs, Koni's, J55 brakes, Nitto 555's, VB&P 32mm front sway bar
mcm95403 is offline   Reply With Quote
Old 12-20-2012, 06:04 PM   #17
garyc4
Junior Member
Quote:
Agree with you on the capability of vortec heads. But I am using either an X-ram or ported CFI manifold. Isn't there an intake port match issue in this case? I thought you had to have a vortec specific intake manifold.
Old 12-20-2012, 06:18 PM   #18
ghoastrider1
CF Senior Member
eldlebrock produces a mainfold that mates the two generations.
Old 12-20-2012, 08:37 PM   #19
powerpigz-51
CF Senior Member
Gary, the flow on all these heads is well documented. The 113's probably should not be used with flat top pistons w/ 58 CC chambers. 64 CC chambers would be as low as I would go on an aluminum head and 72 on anything iron. The exhaust is D port on the 113's, so you would need D port exhaust. You may be limited with your stock intake as to the size of intake ports on your heads. Many aftermarket aluminum heads have a 1206 size port, which your stock intake will not cover up. I am thinking maybe you could run a 1205 port, if you can port out a stock CFI manifold that far. Your intake is less than the size of a 1204 port. Edelbrock RPMs or E streets would be a good choice, but they are D port exhaust. A set of LT1 exhaust manifolds would fit these well. EDIT E Streets are square port, RPM's D port.
Old 12-20-2012, 11:27 PM   #20
84wannabezo6
CF Senior Member
I had my throttle bodies bored by extreme efi I am really going slow on this rebuild/refresh but the throttle bodies seem to be done very nicely but I still need a few weeks to finish so I cant comment on how they work yet.Ive taken a few pics but I havent posted any yet.
Reload this Page L83/L98 head swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
L83 and L98 ps374 C4 Tech/Performance 1 04-27-2014 02:36 PM
L83 L98 heads ps374 C4 General Discussion 0 04-21-2014 08:05 AM
Is it the the actual cylinder head or the compression ratio that makes power jaybird81 C3 Tech/Performance 10 02-25-2014 04:47 PM
AFR 195 Eliminators - Few Questions DanielRicany C4 Tech/Performance 74 01-18-2014 12:24 PM
Another L79 Compression Question milano maroon C1 & C2 Corvettes 12 07-17-2013 08:40 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
