Gears N TPI
Old 12-11-2012, 12:35 PM
91monsta
91monsta's Avatar
Default Gears N TPI
What would be the highest rear end gear ratio recommended for a stock tpi intake? assuming best 1/4 mile et was goal
Old 12-11-2012, 01:27 PM
bjankuski
bjankuski's Avatar
3.45 would be close.
Old 12-11-2012, 02:52 PM
91monsta
91monsta's Avatar
Thats what I was thinking got 3:73 right now n I'm going threw traps at 6500 ish so doubt I'm really pulling at that point got down 3 tenths from stock gears
Old 12-11-2012, 05:48 PM
bjankuski
bjankuski's Avatar
What gear are you in (transmission) and what is your trap speed, 6500 RPM is way too high for a TPI.
Old 12-11-2012, 05:56 PM
91monsta
91monsta's Avatar
Automatic by the way, Traps= finsh line. Over drive unless I'm extremely wrong haha
Old 12-11-2012, 05:58 PM
91monsta
91monsta's Avatar
13.3 at 102 mph I was expecting to drop to a 13.1 with gears that's why I'm thinking I got the wrong set. Looking to port intake in future
Old 12-11-2012, 06:07 PM
vetteoz
vetteoz's Avatar
http://forums.corvetteforum.com/1568185079-post21.html
http://forums.corvetteforum.com/1568186621-post24.html
http://forums.corvetteforum.com/1568212084-post30.html
Old 12-11-2012, 06:34 PM
leesvet
leesvet's Avatar
at that ET and 102...@ 6500, you sure can;t be in OD !
Old 12-11-2012, 06:57 PM
tequilaboy
tequilaboy's Avatar
Old 12-11-2012, 07:57 PM
bjankuski
bjankuski's Avatar
102mph should be 4600 rpm with 3.45 gears and around 5000 rpm with 3.73 gears. Something is wrong with the 6500 rpm that you list, your tach is off. That is a common problem with 1991cars.
Old 12-11-2012, 08:15 PM
91monsta
91monsta's Avatar
Wow thanks alot guys that pretty much sloves my issues when spring comes around I'll know what to do
Old 12-11-2012, 08:26 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Either that or his converter is slipping 20% through the lights.
Old 12-12-2012, 03:09 AM
gerardvg
gerardvg's Avatar
The 3.07 and T700 are a great match as the auto trans first gear is great for launches.
With a manual well 3.45 may be required to get the launch just right.
Old 12-12-2012, 09:46 AM
TLS_Addict
TLS_Addict's Avatar
Only thing I dont like is the big drop off to 2nd gear. Other than that I like the first gear being so low.
To Gears N TPI
Quick Reply: Gears N TPI
