MABBCO engines?
MABBCO engines?
Hi C4 guys.
I have posted this in C3 and now here. You guys helped me get my C3 with an L98 TPI motor running. I was using a very used motor and trans to get the bugs out of the setup (and to make sure I could actually pull it off) I did, but the motor did not survive. Now I need to find a replacement long block, I can mount my TPI on.
I have been looking for a replacement motor for the L98 I have in my 1979 C3. I would like a four bolt, roller cam motor, that I can drop into the C3, to replace the 1986 L98, that just came out of it in pieces. I have found all sorts of reman and crate motors for around two grand, but not many with roller cams, that would let me keep my TPI setup.
So I would like some opinions on this one.
GM Chevrolet 350 5.7 Basic Long Block 1987-1995 Roller 4-Bolt - NO CORE REQUIRED - 90 Day Limited Warranty 5.7 liters 1987-1995 $1,445.00.
Add $50.00 for flat top pistons, 9.5/1 compression with cast iron heads, and $375.00 shipping to my house. Total $1870.00
LINK to MABBCO
Tell me what you think. I would rather get flamed, than burned!
Zorro
LINK to MABBCO
Zorro
Here's some complaints about that company,
They don't mention what machine work is done on the long block
or what brand of parts are used.
http://terriblebusines.blogspot.com/
http://www.bbb.org/east-texas/busine...372/complaints
I was thinking of buying a 454 short block from them for my C-3. I'm really up in the air now. A few bad engines out of how many? Lack of help from them does not reassure me. I think I would brake down the engine myself to inspect it before putting the heads on and installing.
Zorro.
