Back feed diode
Old 01-30-2019, 03:03 PM
gnj3963
gnj3963's Avatar
Default Back feed diode
Hey I am getting back feed from my cooling fan to ignition which is giving me engine run on for a few seconds..The fan was wired direct from previous owner..The temps are a steady 185 - 190.I just want to install a back feed diode in line the fan...Any ideas on where to get one of these from?
thanx
Old 01-30-2019, 03:57 PM
3D-Aircrew
Support Corvetteforum!
3D-Aircrew's Avatar
thanx
You should have a relay driving your fan but if you want maybe this will work. Need to check the amperage rating.
Check out this fan relay kit:
https://www.amazon.com/Hayden-Automotive-3651-Adjustable-Thermostatic/dp/B000C39C72/ref=asc_df_B000C39C72/?tag=hyprod-20&linkCode=df0&hvadid=312098740701&hvpos=1o2&hvnetw=g&hvrand=4210722450349083835&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011700&hvtargid=pla-449801329349&psc=1 https://www.amazon.com/Hayden-Automotive-3651-Adjustable-Thermostatic/dp/B000C39C72/ref=asc_df_B000C39C72/?tag=hyprod-20&linkCode=df0&hvadid=312098740701&hvpos=1o2&hvnetw=g&hvrand=4210722450349083835&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9011700&hvtargid=pla-449801329349&psc=1
Diode
Old 01-30-2019, 05:18 PM
gnj3963
gnj3963's Avatar
Thanx . I will check it out
Old 01-31-2019, 02:02 AM
Hot Rod Roy
Hot Rod Roy's Avatar
This is a duplicate post, answered on the other thread.
To Back feed diode
Quick Reply: Back feed diode
