84 Driver's Side Seat Belt Lower Anchor Bolt ?
Old 10-30-2012, 02:14 PM
GQ-ROD
GQ-ROD's Avatar
Default 84 Driver's Side Seat Belt Lower Anchor Bolt ?
Where can i get a seat belt anchor bolt for the bottom that holds the seat belt mechanism against the chassis next to the driver door ?
Ordered one from ebay and it's the wrong one, looks similiar but won't fit !
Old 10-30-2012, 02:19 PM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
To the halo on a coupe? Maybe to the floor? Where are you located?
I would have guessed floor but if I'm going to pass on information I thought I should confirm!
Old 10-30-2012, 02:34 PM
GQ-ROD
GQ-ROD's Avatar
It's the t50 torx bolt that hols the seat belt retraction mechanism to near the door.
I'm in orlando florida,
i'm confused about your questions though " to the halo on a coupe?
"maybe to the floor ?"
Old 10-30-2012, 02:39 PM
WVZR-1
WVZR-1's Avatar
To the left of the seat "bottom" cushion? Threads into the rocker! Maybe at your shoulder?
Bottom left of seat cushion: GM# 20229360 - It is still available - you could order it. Have a dealer confirm the number in an illustration for you. Should be maybe $6.
Old 10-30-2012, 02:48 PM
GQ-ROD
GQ-ROD's Avatar
Oh yes i'm sorry yes it threads into the rocker correct ! and thank you!! i've been going crazy looking for it EVERYWHERE online.
The one i bought on ebay the seller said it would fit, of course it didn't !
Old 10-30-2012, 02:53 PM
GQ-ROD
GQ-ROD's Avatar
The one i bought on ebay the seller said it would fit, of course it didn't ! ( edit: this was the correct bolt seller was not in error, turns out the thread was galled, difficult to notice on the first few attempts. )
Old 10-30-2012, 03:09 PM
WVZR-1
WVZR-1's Avatar
Shop "LOCAL" !!!
Old 10-30-2012, 03:11 PM
GQ-ROD
GQ-ROD's Avatar
Shop "LOCAL" !!!
Lol yes indeed !! thank you again you literally saved my life! i appreciate it.
Old 11-09-2012, 07:00 PM
GQ-ROD
GQ-ROD's Avatar
Default Update
Thanks to wvzr-1 i got the correct anchor bolt in today, However,
This one did not fit either, turns out it IS the correct bolt as is the one i ordered on ebay,
BUT the prior owner had galled out the thread so neither of these bolts would go in easily.
No matter how you look at the thread on the door sill it does NOT looked stripped, but it is, hard to tell but on the top of the thread it's galled which in turn stripped the first 2 threads of the bolt.
So will have to cut this bolt a little, file the thread, and get a timesert in there to get this bolt to work.
Tried using a tap 12x1.75 but it didn't really do any good on the tip of the bolt as shown.
[IMG][/IMG]
Out of focus but you can see how bad the tip is stripped.
[IMG][/IMG]
Makes sense why the seat belt was not anchored now.
Just want to extend my gratitude again for the help i sincerely appreciate it !!!!
To 84 Driver's Side Seat Belt Lower Anchor Bolt ?
Quick Reply: 84 Driver's Side Seat Belt Lower Anchor Bolt ?
