stuck at work... help
Old 11-20-2012, 08:02 AM
MonteHall
MonteHall's Avatar
Cruise-In VII Veteran
St. Donor '03 & '06
Default stuck at work... help
Drove my 84 into work. It has been carb'd.
about 30 minutes into the drive, the dash wents nuts... segments blinking on and off, all my interior lights turned on, and my radio turned off. I also found my O/D turned on/off with the headlights (but my ECM is pulled so it is purely mechanical. 12v from battery to switch to 1st gear relay to o/d pressure switch)
It drove/ran without a problem. I made it to my spot and shut off the car, looked around under the hood, and tried to restart. Nothing. no lights, buzz, click, etc. not a damn thing.
Old 11-20-2012, 08:45 AM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
I have 12.7vdc at the battery, metal is still grounded, no blown fuses.
Old 11-20-2012, 08:54 AM
lt4obsesses
lt4obsesses's Avatar
It has to be a ground somehwere.
The only other thing I could think would be alternator, but then your battery would be drained and the engine would've slowly died from power loss.
Old 11-20-2012, 08:59 AM
AGENT 86
AGENT 86's Avatar
Sounds like a loose or corroded battery terminal.
Old 11-20-2012, 09:43 AM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
The battery is fine... I checked the ground behind the drivers side head, where else should i check?
Old 11-20-2012, 11:19 AM
THE 383 admiral
THE 383 admiral's Avatar
Fusable link, neutral safety switch,
Old 11-20-2012, 11:22 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Remove both battery terminals, clean and reconnect. Check large red wire going to the alternator.
Old 11-20-2012, 11:25 AM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
Here is a listing of most of the C4 grounds.
P.
File Type: pdf
Old 11-20-2012, 11:34 AM
jhammons01
jhammons01's Avatar
It's your coil.....When the coil starts to go, it makes the dash go whacky
Old 11-20-2012, 02:31 PM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
So I finally had a second to check out the car, hopped in it, turned the key and it fired right up, like nthing was ever wrong.
I was really foggy this morning... moisture somewhere?
Old 11-20-2012, 03:37 PM
jhammons01
jhammons01's Avatar
Coil....
Old 11-20-2012, 05:00 PM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
When I started it, it seemed fine, about a minute in, the dash went crazy again. 4 miles from my house, after 20 minutes driving, hit a red light, and it was like someone turned the key. Done. Same thing as before.
Old 11-20-2012, 05:23 PM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
also the lights tried to rotate but didn't make it all the way when the car died
Old 11-20-2012, 05:43 PM
GQ-ROD
GQ-ROD's Avatar
1- load test your battery
2- clean all connections
3- start going through the ignition system/ lots could be wrong here
4- load test your alternator with a dvom, connect it to battery, have someone start the car, while it's cranking just before it starts if the meter reads 9 volts or less your battery is bad. If you see more or less than 14.5 volts ( when you start it again ) alternator may be under or overcharging killing your battery.
Old 11-20-2012, 10:30 PM
jhammons01
jhammons01's Avatar
This is an old symptom found out years ago on this forum....one of those things that don't make any sense yet you can't argue with success.
A coil is cheap, pop it in and see if that doesn't cure your whacky digital cluster.
Old 11-20-2012, 10:52 PM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
The coil may fix the dash issue, but how about my no start condition?
Old 11-20-2012, 11:20 PM
GQ-ROD
GQ-ROD's Avatar
To stuck at work... help
Old 11-21-2012, 11:36 AM
MonteHall
MonteHall's Avatar
St. Donor '03 & '06
got it flat-bedded home late last night.
after the trip to my place on the rig, I opened the door to press the brake and slide it off the flatbed and all my lights worked, I didn't have the key on me, so we back it down, and I got my keys, put it in the ignition and then it all crapped out again.
ignition switch/cylinder as well?
Old 11-21-2012, 03:16 PM
AGENT 86
AGENT 86's Avatar
Your symptoms still sound like a bad battery connection.
Did you clean and tighten them, or just test the battery with a volt meter ?
Old 11-21-2012, 04:04 PM
jhammons01
jhammons01's Avatar
Fusible links at the starter???
Quick Reply: stuck at work... help
