Idle rough at stop sign
Hello -
I have a 1995 with a Vortec supercharger. Just got finished with:
1. New opti (I am an expert at this repair now)
2. New water pump
3. New wires
4. New Plugs
5. New 02 sensors
At a light or stop sign the car does not idle the best - I put in neutral and it smooths out (but not like my 1999 BMW).
When I took to Ellis Groo at Speed Secrets here in Snohomish Wa. He said when he puts a supercharger in a car he normally changes transmission (I quote "thats alot of stuff your running off of the engine") to a more heavy duty type (he told the name, but I can't remember what I had for breakfast let alone a transmission number)
So here is my question - could this be true? The car has never really idled the best - but it is no worse than before I did all the work. Once the car is going it works dandy.
The reason I did all the work was the water pump oil seal died and leaked oil all over opti yada,yada - you guys kno the drill. Anyway any ideas?
By the way if you guys need a hand putting in an opti I am your man -
Jim Sawyer
2. New water pump
3. New wires
4. New Plugs
5. New 02 sensors
Jim Sawyer
Hello -
2. New water pump
3. New wires
4. New Plugs
5. New 02 sensors
Jim Sawyer
2. New water pump
3. New wires
4. New Plugs
5. New 02 sensors
Jim Sawyer
Engine is stock (as far as I can tell). You question of injectors is a puzzelment. Yes, it has injectors but are you asking for the size and type (if so how can I supply that information to you?). I have not changed anything since I bought car (2 years ago). The supercharger was installed by the Granitelli Bros in SoCal. So what ever came in kit from vortect was put on car as far as I can tell.
No headers but I have been thinking about that.
Thanks in advance Jim
