x pipe
x pipe
is it worth replacing resonator with an X pipe on my DD? not even sure what it looks like under there. is there a Y pipe at each end? then a straight peice of pipe would work or will it be too noisy with magnaflow mufflers?
Received 3,043 Likes
St. Jude Donor '05
It will be louder without the resonator no matter what you substitute it with. The X gets rid of some of the raspy noise from the exhaust.
Other than that they serve no useful purpose.
size xxx flame suit on
For those concerned about noise, you should look at the Magnaflox x-pipe resonator. They make an x-pipe inside a resonator....fairly friendly price IIRC. ($100-$130ish maybe)?
That way you can get you're quiet and 2hp all in the same package!
