Help.. What have they done!! (elec issue)
Just picked up the vette after the trans build in my 89. The builder said has your instrument lights always flash
I said no,they are flickering on off,or mayby just the tach flickering then the speedo.Its as if a short or bad earth..However i can drive for a while and everything works find then it all starts flickering again.
He said at the time ,they only pulled the distributor out,to lower the engine enough to remove the trans then put it back in,have they hooked something up wrong??
Are you able to expand a bit more, is this like an earth strap attached to block or from the distributor.?
was this done when they removed the trans or when they pulled the distributor?
just trying to get a clear picture so they don't look at me strange and can point it out when I go back as the dont work on may vettes downunder :
Some reading
http://www.batee.com/corvette/dcrg/badground.htm
Have VSS ,will email tomorrow
Major ground point is to a big bolt located on engine above the oil filter ; has lots of black wires there
Some reading
Some reading
I've cleared out some messages..
There is a braided ground wire that goes from the frame to the left side of the block above the oil filter, there are also a few ground wires on a bolt to the engine though the gearbox bellhousing. The tach filter bolts on on the left of the gearbox belhousing to engine also.
