Bye Bye TPI
That one has the Vortec bolt pattern but I would guess the clearance would be the same. Dan, your old plenum is now in Texas and will reside on an El Camino.
Too bad it donest have an EO for California.
"This manifold is not intended for use on late model emissions compliant applications."
But it looks good
But it looks good
No one mentioned the throttle linkage being on the "wrong" side. How much fun will that be?
With black/polished valve covers, will look great!
It just so happens I have a pair of polished aluminum, finned valve covers on the way and I plan on painting between the fins with semi-gloss black. Once I get the covers on I will post some update pics.
Received 1,774 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Since you read the Vette article you probably know this, but FAST sells these adapter harnesses for the IAC and TPS:
http://www.compperformancegroupstore...Category_Code=
They are way easier than trying to splice in new connectors, and are only about $10 ea.
#33
I'm just getting started on my intake change project. This intake is not seen very often and I think it may be worth a shot. It is the Edelbrock Pro Flo XT and I really liked the look of it so it was my choice. If it performs as good as it looks, (IMO) then it will be worth every penny of it's $439. price tag. This is just for the manifold, the throttle body and fuel rails are extra but I have just over $800. in all three pieces which is usually what a used superram goes for plus, Vette magazine did a test on it and got 20 more hp over the superram. Here are some pics of it as I just put it on.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#34
Summit Racing has them:
http://www.summitracing.com/parts/EDL-71373/
Certainly is the best looking manifold I have seen in a while.
#35
I got this one from Summit, the manifold was $439. + shipping. Amazon had a natural aluminum one for $419. I got the manifold, fuel rails and the throttle body for just over $800.
#36
Things are starting to get cluttered up now. I have the fuel lines and the vacuum lines all hooked up but if I can figure out something better I will change them around. Here's a couple pics from today,,,
[IMG][/IMG]
Just ignore the valve cover, it is just there to help me figure clearances.
[IMG][/IMG]
Can anybody spot the coil?
[IMG][/IMG]
[IMG][/IMG]
#37
Cool. Which rails and TB did you go with? Hard for me to tell from the pictures if where it says Edelbrock Pro Flo if that is a fuel rail or some sort of cover on the intake. And I'm new to GM's
#38
Where it says Pro Flo XT is the anodized aluminum fuel rails they are $125 at Summit. The Throttle body is a polished Summit brand, it is 80mm and was just over $200. If a person wanted to go cheaper a throttle body off of a '98 (+ other years) Camaro will work but there MAY be hood clearance issues with any other tb. I originally thought I had 1/4 to 3/8 inch clearance but it is actually just under 1/4 right on top of the tb which should be more than enough. I did have to turn my fuel pressure gauge sender down to avoid hitting the underhood light on that side. Any point on the plenum from the tb back has plenty of clearance. I will have to get it up & running to be absolutely sure of enough clearance but a very small bit of grinding & re-polishing of the tb will make for plenty of room. Everything will look a little more finished if my valve covers ever get here.
#40
