Comp Cams Pro Magnums
I'm getting ready to order Comp CamS Pro Magnum 1.6 ratio 7/16" stud non-self aligning rockers for my 90 L98 . Could any of you who have already done this mod tell me the part numbers for the new studs, guide plates and pushrods to complete this. Thanks
Hi.
I have them, but don't have the P/N handy. If you give me 24 hours I will. :) You have to remove a LOT of materiral from the valve covers to make them fit. :)
Cruise-In II Veteran
Re: Comp Cams Pro Magnums (8LivesLeft)
I got the parts from Summit:
P/N CCA-1305-16, Comp Cams ProMagnum RRs, 7/16", 1.6:1, $259.69
P/N CCA-7972-16, Comp Cams hardened push rods, 5/16", $127.95
P/N CCA-4800-8, Comp Cams hardened guide plates, 5/16". $ 26.95
P/N ARP-134-7103, ARP rocker arm screw-in studs, 7/16", $ 28.95
