Need Trans TV Cable Measurement
Old 10-07-2012, 12:07 AM
cimchazz1
cimchazz1's Avatar
Default Need Trans TV Cable Measurement
Can anybody tell me what the distance is from the center of the throttle lever coupling to the cable casing "nosepiece" on a stock 1991 throttle valve cable? It seems like maybe my inside cable is too short in relation to the outside casing. I can get the trans to shift if I set the cable then push the casing back a few clicks (to increase pressure?), but if I go to WOT it pulls the cable out too far and the trans wont shift again. I bot a car that I can't properly set the cable on and it is an aftermarket cable with a square button. Has anyone experienced problems setting an aftermarket cable? There seems to be either a cable problem, or maybe TV spring problem, or something someone screwed up before I got it. Just wondering if anyone else worked through these issues. Thanks
Quick Reply: Need Trans TV Cable Measurement
