I found that annoying vibration pic...rip dana 36
Old 08-23-2012, 10:50 PM
Rob31
Rob31's Avatar
Default I found that annoying vibration pic...rip dana 36
Havent driven the Vette much , working on the house .
Finally got around to the Vette .
When you let off the gas the vibration seemed to go away . I think I have done a couple track days like this .
Im guessing the pinion bearing gave up .
Two teeth off the pinion .
I have a Dana 44 going in its place .
Old 08-23-2012, 11:10 PM
Ramrod92
Ramrod92's Avatar
Cruise-In II Veteran
Had something similar happen to my 36 a few years back.
Old 08-24-2012, 04:02 AM
Ricky 91 vette
Ricky 91 vette's Avatar
nice, i would never dare to mess with the gears like u, even though i can take the engine apart and put it back together, i always thought gears need to be done by a pro... is it that easy or u r a pro?
Old 08-24-2012, 09:04 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
Old 08-24-2012, 09:21 AM
Rob31
Rob31's Avatar
I have only done a couple rear ends . This one was a 3:73 bought on this site from a member . Lasted two seasons . No biggy .
Some one took the time to deburr the case , and the pattern looked good when I put it in . I bought an assembly , looked it over and put it in . I did not set the gears up .
Old 08-24-2012, 09:28 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
While I have done some rearend work, (not on a Vette) I have never set pinion depth which is from my understanding the most critical setting. Since I do have the tools needed to do it I would not be afraid to give it a shot on my own car. I've built my own engines for years and have done the Vette 700R4 and a Turbo 400 trans so if I can whip those a rearend setup should be no problem. Having said that, I hope I never have to find out.
Old 08-24-2012, 10:14 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Theres a whole lot to know to set up a rearend right.
Pinion depth shimming the posi setting backlash, what order to do what, what changes another setting etc.
not worth ruining expensive parts for.
Think I paid $275 to have all new races and pinion bearings installed.
Totally worth it done in 2 hrs.
Rearends are not a bolt in and drive deal.
Old 08-24-2012, 11:36 PM
Ricky 91 vette
about 16 years ago, i have watched a pro doing my dad's truck's rear end, it took him about 3 hours to do the whole thing but i remember him taking long time just to adjust the gears in the case, the rest of the work was faster
Old 08-25-2012, 12:22 AM
ProjectC4
ProjectC4's Avatar
Whoever does the pinion, make sure they change the crush collar. Guys try to get away with using the old one over and it always ends badly. Even machine shops......
To I found that annoying vibration pic...rip dana 36
Quick Reply: I found that annoying vibration pic...rip dana 36
