Need help - I've changed almost everything except the Opti...
Old 08-09-2012, 06:02 PM
npbassman
npbassman's Avatar
Default Need help - I've changed almost everything except the Opti...
UPDATE: It was the Opti. I finally got around to changing it out this weekend (along with a CSR electric water pump) and the car is running great.
..and she still stalls when engine temps get to about 185-190. If you give it time to cool down it'll start right up until it hits temp again and then it's shutdown WITH NO CODES.
Here is what I have swapped out:
- ICM
- Ignition coil
- O2 sensors
- Fuel Pump
- Fuel filter
- TPS
I cleaned the IAC, I checked the FPR and there is no fuel leaking from the vacuum hose. Fuel pressure holds steady at 43psi on KOEO. I did not ohm out the injectors yet. I'm at the point to asking if there is anyone local that has equipment to data log it when it goes down. I can replicate this issue every time. The only thing I can think of is an Opti or ECM replacement.
I'm bummed out that I can't drive it. Looking for help C4 brethren!
Old 08-09-2012, 07:49 PM
87bob
87bob's Avatar
- ICM
- Ignition coil
- O2 sensors
- Fuel Pump
- Fuel filter
- TPS
I understand the bang your head you need a field service manual and follow the porceedure. Others have posted the same symptoms it was the opti
Old 08-09-2012, 10:31 PM
93Rubie
93Rubie's Avatar
After it stalls out and you crank but no start. So you have spark?
Spark checkers are like $5 at Harbor Freight might be a worth while investment? Would narrow it down a bit.
Do you have a healthy layer of Thermal Grease behind the ICM? My 93 starting having a similar issue last winter, it would run find cold, warm, but start to miss hot. If I shut it down, it would NOT restart until cooler. I applied new thermal grease behind the ICM as there was almost none!!! It have been trouble free since.
Old 08-27-2012, 10:41 AM
npbassman
npbassman's Avatar
Update in the first post...
To Need help - I've changed almost everything except the Opti...
Quick Reply: Need help - I've changed almost everything except the Opti...
