Fuel pump by Ecklers
Old 07-23-2012, 02:35 AM
Timo
Timo's Avatar
Default Fuel pump by Ecklers
I have a fuel pump ordered from Ecklers. Ecklers part nr. is 33142. Is this a high-perf pump or rubbish ?
Old 07-23-2012, 09:38 AM
oldalaskaman
oldalaskaman's Avatar
why dont you ask ecklers?
Old 07-23-2012, 10:35 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
I'm sure they just get them from another supplier and stick them in a box. As suggested, call them.
Old 07-23-2012, 09:32 PM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
if your car is anywhere near stock, Eckler's pump will provide more fuel than you can burn
Old 07-25-2012, 03:46 AM
Timo
Timo's Avatar
I have a P-1SC, FMU , 44 lbs injectors, heads, cam etc. Between 5500-6000 rpm at wot, the fuel pressure drops from 75 psi to 65 psi, duty cycle was 82 %, I removed the in-line pump, nothing change. Next i removed the in-tank pump and return the in-line pump, nothing change. I think next i put a 255 L/hr Walbro in-tank pump alone.
To Fuel pump by Ecklers
Quick Reply: Fuel pump by Ecklers
