C4 Engine Pull
Yes, pull it from the side. Just a heads up....the bolts to the trans/block are a PITA to get to.
Also, label every wire, hose and bolt that you remove. Take a few pictures and make drawings. This will save you major headaches when you go to put it back together. If you think you can remember were it all goes......you will be back here begging for help.
Good luck on your project.
Approximately 15+ times here.
For you guys who have done it with the ZF6, do you need to unbolt the C beam and propeller shaft and push the trans back? I usually pull from the front and take the trans with it, but due to space I will be pulling from the side this time. I'm worried about getting enough space to shift it forward to clear the input shaft, without putting a moment on it...
I usually drop the trans since there is no corssmember to support it.
I actually use a chain hoist mounted to a chain around a girder in my attic. I pull the car under the chain hoist, pull the engine out high enough to put it over the windshield, close the hood and push the car out from under it. No engine puller, and I never have to do more than attach the hoist to the chain in 1 minute or less.
A friend had done it and I liked the idea.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I pull the dist and the wiper motor cover.
Takes a few extra minutes but its worth the time savings later
:cheers;
I don't have a wiper motor...wipers scratch lexan.
I wish I had known they were hard to find, I wouldn't have thrown it away I would have paid it forward.
Thanks for the tips. Guess I'll drop the trans. I just hate messing around with the C beam. Who doesn't?
Received 1,766 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Anyone know if the Happy Hooker will work for a Carb style intake? Those bolts for the fuel rails are small, but I guess it holds the engine OK?
yes the bolts hold well, Took mine out with trans still attached and installed with trans still attached, Engine and trans clear perfectly, happy hooker is a great tool for you, I bent the ring on it a bit.
pulled the engine from the side with very little clearances to roll the hoist around.. did have the intake and heads off. wasn't hard.
