84 Knock Sensor
Old 05-23-2002, 10:42 AM
bobpace
7th Gear
bobpace's Avatar
Default 84 Knock Sensor
Is there a simple way to bypass the knock sensor to see if it is working or not. Is the circuit normall open or closed?
Old 05-23-2002, 11:40 AM
JoBy
JoBy's Avatar
Default Re: 84 Knock Sensor (bobpace)
It is a voltage output.
You can check it with a timing light and a friend. Watch the timing with the timing light. Tap on the engine block with a small hammer and the timing should retard.
Quick Reply: 84 Knock Sensor
