Why won't my hood lights work?
I checked all the fuses in the fuse box (tweezers come with the fuse box :cool:.)
No broken fuses, I checked the connection in the hood, and they are definatly connected.
What kinda bulbs does it take?
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Re: Why won't my hood lights work? (Marty McFly)
Check the fuse that is on the backside of the left front turn signal. This is the one you pull to shut off the lights when the hood is going to be open a long time (car shows).
It's encased in a weatherpack connector that is about 3/4" by 1 1/4" in size.
Re: Why won't my hood lights work? (Blue 92)
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
1 Post
Cruise-In II Veteran
Re: Why won't my hood lights work? (cnl3rd)
The '94 service manual calls for 211-2 bulbs, should be the same for yours.
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Re: Why won't my hood lights work? (War Machine)
I believe they were all glass. Like you said, those are some pretty hot temps for plastic lenses to withstand.
