Very Strange Relationship
My horns were not working when I bought my 89 convertible. Neither was the speedometer graph. As for the horns, the relay was clicking and had 12v at the horn connection. Great, just the horns and not the wiring. Took "theadmiral94" advise from his 9/23/2012 post and bought the Fiamm horns from NAPA. Took out the old horns before driving to NAPA. During the trip there, the speedometer graph was now working. Great, something fixed itself, one less thing to do. Picked up the new horns and installed them and they work fine. But now the speedometer graph is again not working. Come to find out, if I unplug the driver side horn. the graph works. Plug it back in and the graph does not work.
Does anyone know how the driver side horn is related to the speedometer graph?
Thanks.
Thanks.
Thanks.
Thanks.
The usual gremlins with wireing is the grounds, they are above the oil filter on the block at the drivers side, if loose they can cause what you are describing.
