Overheating?!?!?!?!!?!?!
Stupid me, I forgot to tighten a hose clamp on the underside and ran it for 2 days befor it blew off on Friday. I further screwed up and tried to run it after putting some coolant in but wasn't enough. When I shut it off my digital display for oil temp was 312 degrees, water temp was 268 before it would not display correctly showed 142. The analog gauges were pegged. Stated blowing blue smoke probably from hot oil blowing by the rings and than I shut it down. There was other circumstances involved, no I wasn't drinking. I was using 0W-30 AMSOIL Signature Series oil and a EA 25,000 mile filter. Had about 12,000 miles on it. I should have just stopped at the first signs of the problem. I can't believe my stupidity on this. I will get it back in the garage, drain the oil and send a sample in and flush radiator and see what happens. May be a long while before I get this running again, probably won't be in my lifetime!!!
Premium Supporting Vendor
I've had the same problem occur at the track when I was at full rpm/throttle. Noted it immediately, but still...
I think testing your oil is a good call and should give you peace of mind that all is well.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
If you have a car that is more efficient with a cooler engine, you should apply for a Noble Prize, because you just disproved the Carnot Cycle. You'll be a billionaire when Ford, GM, BMW, etc. fight over your car. Throw Frigidair, Kenmore, etc in there, too. Infinite energy isn't possible, sorry.
