Ok lowered it and it's not enough. what do you think of this lowering idea?
Sorry for the dirt....
We are in the midst of having 1.5 miles of road re-paved to our house. The car is a mess from the road (and the pollen) right now. It (usually) looks MUCH better than that.
Mike: I understand...I just don't trust a hole drilled through a spring never "intended" to have one, and don't trust it.
If it is working for you...great. It isn't something I'd ever do to my car though.
Does anyone take the suspesion geometry into consideration when lowering the car? camber curves roll center bump steer etc? Or is everyone just going for a look as in if it looks fast it must be. I will grant you lowered the center of gravity an inch maybe 2 but there is a bunch more to it than that. It is a shame no one makes a dropped spindle as that would be the fastest easiest way to go and not screw with the geometry.
[QUOTE=1991Z07;1580396996]
My Z07 with the lowering kit looks JUST like this...
Of course...mine is white and looks better
But that blue is very nice as well.
QUOTE]
WHite is nice as well but you need the front oz monte carlos up front and not 4 rears because the rears are 10" wide and the spokes look tiny tucked in for the added width. Those 18s look like 17s !
This is how oz's are done
Here's how to do a white c4... coincidentally.. by me (except for the hash stripes.. owner did that ugh) !!
QUOTE]
Dave
My OZ's have 295's on them, and that was the look I wanted. The offset has the tires JUST inside the fender lips.
But I didn't really do it for looks...I actually drive the car as intended, and it sticks like glue around turns.
@ddahlgren: Yes, I actually took geometry into account when making my changes. I have all the DRM brackets for the rear, and after making the changes to the suspension I took FTD's in the first 5 or 6 autocrosses I attended. No other changes were done over the winter except the suspension...and I gained about 1.5 seconds on short courses.
Here is a picture of my car at TWS. This particular weekend our club had the SpeedGT cars from GrandSport Speedway attending our high-speed autocross. I was lapping 1 second slower than them, and I had about 500+ lbs on their '96 and 2001 Z06 (#18 of the 24 or so sold in the crate from GM).
So, yes...the changes worked fine for me.
Well I've been thinking of using a kit made for newer corvettes to take care of the steering arm misalignment of being lowered. I don't think they sell one for a c4 so I'm hoping the newer corvette kit will fit. I'm also setting up my car with a bumpstop to keep from bottoming out the shocks and ruining them and I set up the front skidframe with a roller in it so it would roll over speed bumps rather than drag over them. I tried to think about what problems it might have being lowered and fix them.
Absolutely! The others have some ingenious ideas but I don't think I would want either setup on a street car. No potholes on a race track. This is merely my opinion and in no way a slam against Kubs or Aardwolf both of your solutions look great,,, for a race car.
Sure, some people say you plan for the 80%...but I always plan for the 98%.
For the expense, engineering and time...a $1700-$2250 KNOWN solution with DRM coil-overs beats a WAG (wild-a$$ed guess) for me every time.
Originally Posted by 1991Z07;1580396996
[IMG
[IMG
http://i278.photobucket.com/albums/kk110/jraymond91vette/IMG_0637.jpg[/IMG]
#33
