Turn Signals
Old 03-31-2012, 06:10 PM
Mikepro76
Mikepro76's Avatar
Default Turn Signals
I have a 1990 and my right turn signals are not working. Left are working. When I turn on the right there is nothing, no lights, sounds, or blinking. Would it be the flasher even though the left side works? Is there a fuse for it? If it is the flasher where is it located on a 90?
Old 03-31-2012, 07:27 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
There is a good change you have a bulb burned out.
If a bulb is burned out, that side will not flash.
Replace the bulb for the light that isn't lighting up.
Old 03-31-2012, 09:27 PM
1986coupe
1986coupe's Avatar
Check the bulbs first. They are easier to get at.
The flasher is in a really awkward place...under the passenger side of the dash. You need to remove the panel under it and look up. When I found out where it was, I checked my bulbs and solved my problem.
Old 04-01-2012, 08:16 AM
Mikepro76
Mikepro76's Avatar
Thanks. I did not realize the bulb being out would stop the side from working. I will start there.
To Turn Signals
Quick Reply: Turn Signals
