1996 power steering pulley
Old 03-21-2012, 02:27 AM
mike88amped
4th Gear
mike88amped's Avatar
Default 1996 power steering pulley
Ok I have seen tons of post on this subject and I have spent alot of time checking places....I need a power steering pulley for a 1996 lt1 Corvette . I have tried several places listed in the post,but everyone says they are no longer available,spent a half hour on phone with speed inc.today and they could not find one either.any help would be great thanks
Old 03-21-2012, 05:00 PM
mike88amped
4th Gear
Default Help
Anybody out there help!!!!!!!!!!!!
Old 03-21-2012, 05:10 PM
Jonnymac
Jonnymac's Avatar
St. Jude Donor '08
found mine on ebay. good luck
Old 03-21-2012, 06:52 PM
bjm206
bjm206's Avatar
The link below allows you to search across multiple salvage yards for parts by distance from your location.
http://www.mypartshop.com/
I saw a few hits on pumps from your model year. Give one of them a call and see if they will just sell you the pulley or if not sell you a pump with the pulley.
Old 03-21-2012, 07:02 PM
mike88amped
4th Gear
Default thanks
thanks for the info i will check it out...
Old 03-21-2012, 10:25 PM
93Rubie
93Rubie's Avatar
That would be smooth sided steel pulley, yeah, good luck. No one makes them anymore. All that is available is Ebay, swap meets, salvage yards. I got one last year from a Corvette Salvage yard.
Ironically, they make the 92-E93 plastic ones. $400 a pop.
Why do you need one?
Old 03-21-2012, 11:15 PM
mike88amped
4th Gear
Mine has a really bad wobble in it and I have been through 2 altenators ...had it checked by GM dealer and they say the wobble is causing problem with alternator bearings
Old 03-22-2012, 08:45 AM
Muffin
Support Corvetteforum!
Muffin's Avatar
No question about needing a straight pulley but I wonder about causing alternator bearings to fail. Idle thought: can a pulley be straightened?
Old 03-22-2012, 10:50 PM
93Rubie
93Rubie's Avatar
In theory, it could make the tension from the belt misaligned and the load the bearings in a way they where not designed to be loaded.
I would check your idlers and tensioner as well for good bearings/no play,etc...Check pulley alignment with a straight edge, specs. are in FSM.
What I want to know is how does a steel pulley get bent?
Old 01-29-2013, 11:13 PM
derekguzz
derekguzz's Avatar
Well mines bent as well and looking for a replacement
Old 01-30-2013, 12:37 AM
gerardvg
gerardvg's Avatar
Remember do not try to fit a new one, or remove one without the correct removal/fitting tool or you will need another.
http://www.ebay.com/itm/KASTAR-Maste...item257a47bc5c
Old 01-30-2013, 12:50 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
A bent pulley would indicate either an incorrect removal proceedure OR a failed attempt at an install when replaceing a pump. The only other possible explanation is that presently it's not a pulley problem but the shaft or front bearing in the pump has failed or is failing. Just sayin'
Old 01-30-2013, 09:25 AM
Txbobcat
Txbobcat's Avatar
I sent you a pm of a guy that parts out c4s. He will have your part
Old 01-30-2013, 01:23 PM
pmihaltian
Slingshot
pmihaltian's Avatar
I rebuilt my entire power steering system this past year and used this inexpensive pulley removal & installation kit to do the job. Worked great without error or problems. Check it out:
http://www.harborfreight.com/pulley-...set-40749.html
Old 01-30-2013, 02:48 PM
ScaryFast
ScaryFast's Avatar
I have a complete pump, rebuilt by turn one for sale cheap.
To 1996 power steering pulley
Quick Reply: 1996 power steering pulley
