VATS ??? ALARM GOES OFF 92 vette
Old 03-20-2012, 05:20 AM
mjfox
mjfox's Avatar
Default VATS ??? ALARM GOES OFF 92 vette
thanks in advance to all
sitting in bedd last night my vehicle alarm goes off checked out car no break in reset with remote
1 hour later it goes off again.
any idea what problem could be.
thanks mike
Old 03-20-2012, 09:46 AM
markKlein
markKlein's Avatar
Doesn't sound like VATS. Check the "door open" switches, make sure they are working OK. Maybe check the battery too, make sure it isn't getting weak. Hopefully someone has some better ideas than I do.
Old 03-20-2012, 10:23 AM
Nathan Plemons
Nathan Plemons's Avatar
Sounds like a door switch. I've had it happen to mine before with the top out, these cars flex a LOT.
Old 03-20-2012, 10:39 AM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
thanks mike
Do you have an aftermarket alarm system?
1992 didn't have a factory remote.
Old 03-20-2012, 11:35 AM
mjfox
mjfox's Avatar
Default I have a afactory installed auto start
I have a factory installed auto start
thanks mike
Old 03-20-2012, 11:47 AM
mjfox
mjfox's Avatar
thanks mike
anyone know the switch part #
Old 03-20-2012, 12:17 PM
markKlein
markKlein's Avatar
thanks mike
No, you don't. There were none. You have an aftermarket alarm system, which may not be playing well with the factory system. But I would check out the switches first. Don't forget the hatch switch too, if you have a coupe.
Old 03-20-2012, 12:50 PM
jispr
jispr's Avatar
Same thing here. Turned out to be hatch switch. out of adjustment.
Car would get hot and not touch switch
Old 03-20-2012, 01:54 PM
mjfox
mjfox's Avatar
Are these switches on the door and hatch
normally open or normally closed
To VATS ??? ALARM GOES OFF 92 vette
Quick Reply: VATS ??? ALARM GOES OFF 92 vette
