Em longtube,spark plug install question
Hey guys,putting new plugs on the 92 lt1 and i cant tighten two of the plugs,as the header primary tubes are in the way,any tips or tricks to go at this,i tried from underneath but still not much room to work,worst comes to worst ill loosen the header bolts but there a tight fit to tighten also i rigged a wrench for that.
thanks mike
thanks mike
Go from underneath the header tube with an open end wrench on the socket.
Cruise-In II Veteran
If you are lazy like me, you can just find a short socket like this on ebay. $13.00 shipped. For a good laugh, check out what SLP wants for thiers.... http://www.ebay.com/itm/SLP-Performa..._Tools&vxp=mtr
I use an offset box end 5/8 wrench to get to a couple of my plugs. Makes it easy. Anyone carries these.
