Thoughts on this block
I'm looking for some opinions on buying one of these blocks from summit versus buying a shortblock from a friend. The way I see it, the block from summit would be cheaper in the long run. My friend says that he doesn't like the fact that the cylinder bores are already honed, but I don't see what the problem with that is...
http://www.summitracing.com/parts/SUM-150100/
Do you mean your friend's short block or your friends block? A short block has pistons, crank, rods and that to me sounds way better than just a block you would have to assemble. Unless you are going for something different like upgrading.
I think if you are more specfic on what you are doing you might get better answers. Depending on what you are going for depends on which block would be best.
Have you built an engine before? Why would you buy a short block 350, which presumably has all the work done on the crank, rods, and pistons, then throw all that away to build a 383? Will you want to use the same camshaft? He must be giving one heck of a deal!
Received 3,043 Likes
St. Jude Donor '05
Different pistons/ring packages may want a slightly different finish hone on it to fit perfect is only thing to really be concerned about (for ring seat/proper piston to wall clearance)
Find out what piston you want to use find the spec sheet on it go from there.
This will be my first build, but I have watched my dad build enough when I was younger to know what I'm doing. The shortblock he has came out of a truck and he just took off the heads and intake, so the crank rods and pistons have some miles on them. Everything in theis engine is stock.
- 1986 Original Owner -
I'm using one. Got it last March. Can't believe it's been a year and I'm still working on it! I'm pacing myself, Sergent.
http://forums.corvetteforum.com/1577219642-post14.html
Here is what it's looking like now:
St. Jude Donor '05
Details on the build?
Is that a polished base I see?
Regarding the original question: The block is not a bad deal but I wouldn't want the bores to have their finish hone. In addition I would want to know if the block is decked, has it been align bored (it looks like it was just honed), etc. Lots of unknowns. Even once you know the answers, you'll still want to have it checked by a machine shop to verify all the work. Way too much time, effort, and money to blindly assume that everything is ok.
....this won't end well.
So as others have suggested, best not to uncrate and start building, but have your machine shop give it a once over. Only you can decide if it's a good deal for you. Good luck what ever you decide to do.
St. Jude Donor '05
Hey Mike! Things have changed a bit in my work schedule and it's looking like I may not be able to make it. It's a long way off, so it may still be possible, but looking more and more unlikely at this point. I will be going to the DC area at the end of the month though if anyone in the area wants to meet for an adult beverage or five!
As I said in the original post, after clean up of the rust, the bores were fine for my SRP forged 30 over pistons. I did have my machine shop do a finish/plateau hone for the JE rings that I used. Also had the machine shop do an align hone. They said it would have been alright as is, but as I was swapping the main bolts for ARP studs... Again from my original post, during preassembly, I found the piston to deck varied from 8 and a half to 14 and a half thousandths in the hole. Had the machine shop deck it and during the most recent preassembly, the piston to deck is now within 1 thou of zero deck.
