Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-04-2012, 01:48 PM   #1
94c4er
Junior Member
Default C4 Ground Locations
I am having intermittent missing on my 1994, changed Opti, Plug Wires, ICM, Opti Harness, fuel injectors, fuel pump, etc. Battery and alt were changed but not because of these problems. Runs fine sometimes and then starts missing above 2K. Everything now is pointing to a possible bad ground or PCM. I can find the ground locations for a C5 but not C4. Can anyone tell me where all the grounds are so I can check and clean them???
Once I figure out the problem, I will post the fix.
THANKS!!
94c4er is offline   Reply With Quote
Old 03-04-2012, 06:19 PM   #2
leesvet
CF Senior Member
leesvet's Avatar
huh uh-huh
THANKS!!
There is a ground on or near every electrical system on the car...everywhere.
BUT, the most interesting bunch are on the block or bellhousing bolt near the oil filter. These include the ecm, interior, most engine sensors, and other misc display and control systems. Not easy to access but critic to have in good condition.
leesvet is offline   Reply With Quote
Old 08-07-2013, 05:19 PM   #3
Grizeg
Junior Member
thought you were going to post a solution.........
Grizeg is offline   Reply With Quote
Old 08-08-2013, 04:17 AM   #4
Cliff Harris
CF Senior Member
Cliff Harris's Avatar
Here's a link to the ground locations on an '86. I doubt that many of them moved over the years:
http://home.earthlink.net/~cliff_har...s/grounds.html
I would suspect that your problem is more likely to be either a corroded contact in one the ignition related connectors or your ICM does not have THERMAL grease under it. Some people use dielectric grease by mistake, which will NOT work and cause the engine to cut out when the ICM gets hot. Another possible cause is a loose spark plug wire connector at the plug.
Cliff Harris is online now   Reply With Quote
Reload this Page C4 Ground Locations
Tags
1984, 1994, 84, bad, block, c4, check, coevette, corvette, ecm, ground, grounds, locate, location, locations, problem
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LT1 question BeanCntr C4 Tech/Performance 25 08-02-2014 12:51 AM
Name the things that will cause a LT1 MISSFIRE! smooth1990 C4 Tech/Performance 6 06-12-2014 09:27 AM
Help with opti attachment Sleazy Rider C4 General Discussion 10 05-24-2014 02:20 PM
Opti oil leak, HELP!!!!!!!!!!!!!!!!!!!!! llesg C4 Tech/Performance 18 01-24-2014 08:46 PM
Need help - I've changed almost everything except the Opti... npbassman C4 Tech/Performance 3 08-27-2012 10:41 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
