Disconnect Timing Ignition On?!
Old 06-23-2021, 05:45 PM
kael
Support Corvetteforum!
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
Default Disconnect Timing Ignition On?!
Howdy all. Resetting my minimum idle after engine rebuild, '87 L98. FSM instructions includes the following:
4. Turn ~~ON" ignition, do not start engine. Wait at least 30 seconds.
5. With ignition ~~ON", disconnect lAC electrical connector.
!Important! Disconnect the distributor set-timing connector.
6. Start engine and allow to go Closed Loop".
Is it safe to disconnect the timing connector with ignition on, engine stopped? Double checking before having to get another ECM. Or worse.
Old 06-23-2021, 06:21 PM
Mrvettenick
Mrvettenick's Avatar
No, it shouldn't be an issue.
kael (06-24-2021)
Old 06-24-2021, 10:51 AM
kael
kael's Avatar
Did as instructed, no issues.
To Disconnect Timing Ignition On?!
Quick Reply: Disconnect Timing Ignition On?!
