96 Grand Sport LT4 leaking oil.Common?
St. Jude Donor '08-'09
A friend of mine is considering buyind a low mileage LT4.He noticed oil on the floor when the seller moved the car.Are oil leaks common on the these motors and are they fixable?He's not sure but he thinks it is the rear main.
Received 3,043 Likes
St. Jude Donor '05
Show me a Chevy that never leaks oil (except for LSx motors)
Could be an intake they have a tendency to leak at the rear, oil sending unit too. Wouldnt worry about a slight drip except the work to fix it.
Every 2 pc rms (older) has leaked almost upon startup. Let em leak til it gets bad
Easy fix for any competent DIY mechanic...$35 for gaskets and about 90 minutes of time.
2+ years (current engine, 383 build) and no leaks:
Ok....exception rather than the rule
St. Jude Donor '05
Old engine coming out. 4+ years and thousands of track miles....no leaks:
Use the oil drops as a barganing tool. Tell the seller it looks to be fatal. Have him drop his price $500 for a seal replacement and drive away with a smile and put a $8.00 drip pan under your car.
I gave up trying to fight oil leaks a long time ago. I resigned myself to the fact that unless I get the chance to pull the engine completely out and replace every seal on it at the same time and under ideal conditions, it's just gonna leak. If I do have to pull my engine completely, it's not going back as a stock 350, so it's just gonna leak for a while.
A good friend of mine works at the local Chevy dealer. He says the only SBC's he worries about are the ones that DON'T leak.
Received 1,768 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
My '90 didnt leak a drop for 115K miles (I only owned it since 90K, but it didnt leak when I got it). Finally it started leaking when I broke the piston rings and it blew oil out the valve covers.
