Head gasket reccomendations?
Old 02-08-2012, 01:13 AM
corvette_bob
corvette_bob's Avatar
Default Head gasket reccomendations?
I'm probably going to pull my heads off for porting later this year. When I put them back on I'd like to use a good head gasket that's going to last like my OEM's have but I'm hoping to use a gasket that'll have a thinner compressed thickness as well so's I can increase my compression a bit. And yes, I'm planning to use new head bolts.
Old 02-08-2012, 07:06 AM
oldalaskaman
oldalaskaman's Avatar
your best bet would be the gasket recommended by the person doing the machine work
Old 02-08-2012, 02:21 PM
desertmike1
desertmike1's Avatar
Felpro.
Old 02-08-2012, 02:52 PM
PLRX
PLRX's Avatar
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Old 02-08-2012, 03:01 PM
GREGGPENN
GREGGPENN's Avatar
C4 of Year Winner (appearance mods) 2019
Cometics are the "Cadillac" of head gaskets. Pro Comp might still be making a knock-off -- which might be an option. I used actual Cometics -- as recommended by my builder.
They come in varied thickness, but the final determination would come from your head condition.
Victor Reinz .026 gasket is often recommended for our stock vettes. With the stock .025 piston-in-hole depth and chamber size, the .026 gasket gets you closest to proper quench.
Even if you shave off .01" to clean up heads.
Old 02-08-2012, 11:50 PM
corvette_bob
Thanks very much for the input. Do you know of a source or p/n for the Victors?
Old 02-09-2012, 12:41 AM
GREGGPENN
GREGGPENN's Avatar
To Head gasket reccomendations?
Quick Reply: Head gasket reccomendations?
