Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2012, 07:40 AM   #1
raiderz
CF Senior Member
raiderz's Avatar
Default Benchtest a digital dash
Hello:
I have a digital dash out of my 86 that i have done a few different solder repairs to.
How do i bench test this unit to see if everything is working??
I bought a used replacement dash that is in the car right now.
Thanks in advance
Ray
raiderz is offline   Reply With Quote
Old 01-15-2012, 10:29 AM   #2
HlhnEast
CF Senior Member
HlhnEast's Avatar
I think GM had a machine to test these dashes. I assume you went to batee.com for your basic info. Look for the wiring diagrams and schematics for the connector pin values and at least make sure your inputs are correct. That should help determine whether or not the fault is at the dash.
Other than that, plug it in and see.
HlhnEast is offline   Reply With Quote
Old 01-15-2012, 12:56 PM   #3
raiderz
CF Senior Member
raiderz's Avatar
Yes...Batee.com is where i got my direction from.
I was hoping to avoid having to haul the dash apart again just to test this repaired unit.
Thought i might be able to apply some voltage to a few pins on the plug-ins and light something up that way.
Old 01-15-2012, 08:11 PM   #4
golfnstuff
CF Member
Default Test device for Digital Instr. Cluster
I've seen a test device offered for about $275 dollars on-line. It was a private builder of the device. It's a real pain to disconnect the cluster and then re-connect to test it. I'd like to build a longer pigtail connector so I could plug it in temporarily outside of the dash but haven't been able to find the 24 pin and 32 pin male and female connectors to do this. I've done a couple cluster repairs myself and have had to bite the bullet and just re-install it. Some of the Vette repair shops do have the test device but I don't know what they'd charge to just test your cluster.
golfnstuff is offline   Reply With Quote
Old 01-16-2012, 06:25 AM   #5
Ray Quayle
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Support Corvetteforum!
Ray Quayle's Avatar
It depends on how much you want to test. My tester can generate all the sensor inputs, including VSS. If you simply need to verify that all your lights and LCDs are working, the initial self test that the cluster goes through when power is first applied would suffice.
Here is a cluster on my bench when power is first applied:
Click the image to open in full size.
Here is is with simulated inputs:
The pins you'll need are all on the 32 pin connector:
This is from memory, but to get the cluster to self test, all you need to do is apply 12vDC to pins C16 and D16 and a ground to pin D1.
__________________
Ray Quayle
'86 Indy PaceCar, 4+3 (6895 of 7315)
Lcdr Operations Officer USS Corvetteforum SSB Y2K Gold
NCM Founder #2896
NCM Lifetime #672
Graduate of Gordon's School
Black Sheep Squadron Member
Ray's Corvette
ray_quayle@btopenworld.com
Ray Quayle is offline   Reply With Quote
Old 01-16-2012, 07:35 AM   #6
Geardo
CF Senior Member
Geardo's Avatar
Great info
Geardo is offline   Reply With Quote
Old 01-16-2012, 08:42 AM   #7
raiderz
CF Senior Member
raiderz's Avatar
That is fantastic information...Thanks Ray Quayle.
I think i'll give the power up test a go.
I changed the big 12 pin connector that joins 2 boards together. Mine was burned pretty bad and i was getting no display lights in the coolant temps/volts area. I also dropped some more solder on a more than a few suspect looking areas.
I will probably spend the hour or so in the spring and swap out the dashes to verify all sensors are working with the repaired dash.
Thanks again for the great info..........
Reload this Page Benchtest a digital dash
Tags
bench, c3, c4, cluster, clusters, corvette, dash, digital, gm, hook, instrument, light, sale, test, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
