Help... stripped Battery Connector Stud...
1986 ..... dreaded dead battery in NJ..... was nice day and went to move car in small 1 car garage to get snowblower to behind car and battery was dead....... got the battery out and went to put the new one in and as usuall my Positive stud won't go in....... checked it against the Neg stud and it looks like its seen its best days and is stripped....The studs seem to be locked into those connecters .... can anyone give me some tips how to change out the stud...... I'm working in a tight space too (small old 1 car garage in house form the 1950's...
Please help ... has anyone changed these out and how???
Thank You...
Thank You...
Thank you I'll give it a try in the morning ... with help of sunlight...
If anyone else has done this let me know...
BTW is this common............. that spot is so tight in there....
But with a little effort, you can wiggle them out and replace with new studs.
I just did one today. Grab the hex with a vicegrip, and pull while twisting. When you push in the new one, a tiny dab of grease on the inside of the rubber part of the terminal will help.
On mine the shoulder on the new stud just would not go past the rubber like plastic. Just took a razor knife and trimmed it a little. I guess its been a year or so.
Thanks everyone, I just never did one before and had the nightmare of yanking out the cable. I'm not a mechanic but managed to change out the battery since 1986 a few times,,, so guess who probably stripped this one.. I always just like the input here of people who may have a trick or two to get it done.. and have done it before. The vicegrip sounds good and it does sound simple........ but so has been just reconnecting the damn battery the last how many times till this one,,, I've done that a few times with ease, except this time and with the battery brand new and the stud not going in, I can see its stripped.
Once again thank you all and I'll send in for my badge when I get it done LOL...
what size stud can I use....
Seems like a stud that is a little longer would make life a lot easier or do you risk damaging the battery?
Has anyone used a longer stud? My car is 86..
I believe all of the positive battery bolts for a side-terminal battery are the same size. (the threaded side)
I have seen some which were a little longer on the side where you would put your wrench.
Sometimes folks install extra eyelets at that connection for radios and other such electrical items. That would make starting the bolt a little trickier.
SAVE the WAVE!
SAVE the WAVE!
