NOS Control Arms or Rebuild with MOOG??
Sorry car shows and waxing are not my thing. My definition of enthusiastic passion is driving the hell out of it which is exactly what I have done over the years, on and off the track.
My vote goes for the NOS parts...I was in your same position last spring and ended up going the NOS route. No messing with grinding rivets to replace the upper and getting new control arm bushings pressed in.
Much easier when everything is assembled and you just have to replace the whole control arm.
If I could do it over again, my suggestion would be to lower the front end at that time if you ever plan to. Wish I would have done that when I replace the control arms. Corvette recycling is a great company to do business with
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
Two more cents from the peanut gallery....I did the corvette recycling front wish bones and that was 25k ago. They worked out great! Yes the OE rubber may be a bit old but I just keep an eye on them. They are starting to show some spider web cracks but nothing major.
I would advise against the poly stuff unless the roads you drive on a glass smooth. Up here in the NYC/Metro area that's not the case! I swapped out the endlink bushings to poly using the VB&P end link kits & did the rack mount and front bar mounts and I can feel the difference just from that and it's not good on bad roads! On smooth roads I can feel the difference and it's just crisp enough without being touchy so I like it. The ride harshness and transmitted vibrations are a bit more thru the car. I'm glad I didn't go the total poly route for the street.
Tom
Tom
The ball joints on her car looked just like yours, but without the gray patina. We rebuilt the front end with Energy Suspension components (poly) - every joint and bushing in the front end, plus tie rod ends. It made a much steadier car, no squeaks or groans when driven...and I know the streets in Metairie aren't worse than the ones in Jackson.
