Help Wipers and AC on at same time Blows AC clutch Fuse
Old 06-19-2011, 02:59 PM
93VettePilot
93VettePilot's Avatar
Default Help Wipers and AC on at same time Blows AC clutch Fuse
When I turn on the wipers and AC at the same time it blows the AC clutch fuse. This takes the AC control head offline and renders the environmental system inop. I can use the AC by itself no problems. I can use the wipers by themselves no problems. It requires a 10 amp fuse which blows rather quickly. 20 amp fuse will allow me to use the AC and wipers at the same time.
When running the AC and wipers at the same time I can see a surge on the ammeter and all the lights on the dash dim with each sweep of the wipers. I've looked at the factory service manual wiring diagram and can't see how the two systems are related.
Anyone ever have this problem before? Wiper motor bad? Bad ground?
Update: I fixed this problem. The Accel Gen 7 computer had low resistance in the IAC stepper circuit input line(increases IAC when AC compressor kicks on). So the AC Clutch circuit was basically shorting to ground. Not sure why the wipers surged and caused the AC fuse to blow but its fixed now.
Old 06-19-2011, 10:24 PM
93VettePilot
ttt
Old 06-20-2011, 09:06 AM
oldalaskaman
oldalaskaman's Avatar
I vote , bad ground
Old 06-20-2011, 10:25 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Wipers should not be on the same circuit as the ac. They have their own breaker in the fuse panel. Someone must have rewired the car. Check the wiring and find out where the wipers get their power from and rewire back to the panel.
Old 06-21-2011, 12:39 AM
jfb
jfb's Avatar
Originally Posted by oldalaskaman
I vote , bad ground
A bad ground would cause lower current in those circuits.
The wiper is on its own 25 amp fuse and is unrelated to the A/C system. A/C compressor clutch has its own 25 amp fuse. Check for changed wiring!
Old 06-21-2011, 09:59 PM
93VettePilot
Keep in mind... my car is LT1 with 30 amp wipers and 10 amp AC clutch...
I've been going through the factory troubleshooting for the wipers and I'm about 90% sure the wiper switch is bad. I still don't see how this could affect the clutch fuse but hopefully it will solve my problem.
Old 06-21-2011, 11:05 PM
jfb
jfb's Avatar
I was using the fuse sizes from my 87 and I don't have a schematic for your year, but I am certain that there is no connection whatsoever between the wipers and A/C clutch wiring and you should not experience fuse blowing when both circuits are on! A previous owner must have rewired those circuits.
Old 12-16-2011, 08:18 AM
93VettePilot
Fixed. See 1st post
To Help Wipers and AC on at same time Blows AC clutch Fuse
Quick Reply: Help Wipers and AC on at same time Blows AC clutch Fuse
