Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-06-2011, 07:29 AM   #1
My1st
CF Senior Member
My1st's Avatar
Default Replacement Auto Transmission?
I need to either replace or have my transmission rebuilt this winter in my 89.
Iím seeing a lot of low mileage 700r4ís for sale but which ones will work?
Does it have to be out of a corvette or do you just replace the tail piece so you have the mount for the C-Beam?
My1st is offline   Reply With Quote
Old 12-06-2011, 07:52 AM   #2
leesvet
CF Senior Member
leesvet's Avatar
huh uh-huh
It needs to be out of a Vette or get recon with a Vette kit. The valve body has some control parts that are specified "Corvette Only" that control shifting and how hard/soon shifts are made working with the TCC and TV cable.
leesvet is offline   Reply With Quote
Old 12-07-2011, 03:52 AM   #3
Cliff Harris
CF Senior Member
Cliff Harris's Avatar
There are multiple differences between the various years of 700r4s. The main thing to watch for is to get a '88 or later. They made many changes in late '87 to fix problems with earlier years.
The Corvette specific 700r4s have a large "V" molded into the side of the bell housing. The main differences are a special valve body (and corresponding case passages, called "worm tracks") and larger servo.
You can use a non Corvette transmission by swapping the tail shaft housing (you need the C beam mount). The output shaft is shorter on a Corvette, but you can cut off the end to make it compatible. You won't be happy with the result.
Cliff Harris is offline   Reply With Quote
Old 12-07-2011, 08:03 AM   #4
Flame Red
CF Senior Member
Flame Red's Avatar
Take my advice, have your original rebuilt by someone that has a good reputation and do not replace it. There are many specialized internals in the Vette tranny, and if you get some other GM unit it might end up shifting like a truck. Ask me how I know...
Flame Red is offline   Reply With Quote
Old 12-07-2011, 08:21 AM   #5
My1st
CF Senior Member
My1st's Avatar
Quote:
Thanks, I was thinking the same thing. Iím not sure whatís wrong with mine it shifts just fine through the gears but when I hit passing gear the RPMís go up but she donít go. Very bad slip.
Old 12-07-2011, 06:26 PM   #6
cadmaniac
CF Senior Member
cadmaniac's Avatar
Not to mention the tailshaft housing and overall length is different to the corvette!!
cadmaniac is offline   Reply With Quote
Old 12-07-2011, 09:01 PM   #7
383vett
CF Senior Member
383vett's Avatar
I've got a passenger car 4l60e with a shift kit. 5/8" off the outputshaft, Corvette tailshaft housing. It works pretty well.
Click the image to open in full size.
383vett is offline   Reply With Quote
Old 12-07-2011, 10:16 PM   #8
Marv02
CF Senior Member
Marv02's Avatar
My 700R4 out of a Truck it has thicker K case.
The inspection cover is cast aluminum the tail shaft been cut down 3/4 inch for the Vett tail housing shift kit works great for me.
I asked around before I replaced my stock 700r4 mainly it was rebuilt 4 times everytime it came back worse so I said enough is enough it's time for anouther trans.
I went with a performabuilt.
http://www.performabuilt.com/
No core I not pushings Meg HP but so far I glad I purchased this trans I had about 6 months now and 5000 issues free miles on it.
Marv02 is offline   Reply With Quote
Old 12-07-2011, 10:41 PM   #9
twin540
CF Senior Member
Support Corvetteforum!
twin540's Avatar
Quote:
It can also be you're converter.
twin540 is offline   Reply With Quote
Old 12-08-2011, 12:28 AM   #10
pricesgarage
CF Senior Member
pricesgarage's Avatar
corvette and gmc syclone and typhoon had the best 700 r4 calibrations definally stick with a vette tranny
pricesgarage is offline   Reply With Quote
Old 12-08-2011, 12:35 AM   #11
87 vette 81 big girl
CF Senior Member
Have your original 1989 C4 trans rebuilt & blueprinted.
Find the best transmission man in your area with experience building 700R4 & 4L60 E transmissions.
Pete K is an excellent veteran auto transmission man here on C4.
I have had 100 % success rebuilding & blueprinting my own 87 vert 700R4 trans.
Either 1 of us can help with C4 auto trans tech.
Pete sold his own transmission rebuild hand picked kits & torque converters in the past.
He may still do so yet today.
have to ask him.
I sourced all my own parts needed piece by piece for my 700R4 trans.
BR
87 vette 81 big girl is offline   Reply With Quote
Reload this Page Replacement Auto Transmission?
Tags
1984, 1994, 1996, 84, auto, body, c3, c4, corvette, kit, replace, replacement, tailpiece, trans, transmission, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
