Tune after stall install?
Old 11-22-2011, 12:05 AM
F.G.
F.G.'s Avatar
Default Tune after stall install?
Hi everyone, I've searched but haven't found threads on this. I think I know the answer but just want to be 100% sure. On a 92 Corvette with the 4L60/700R4 do I need to get a tune when installing a higher stall torque converter? Thanks in advance
Old 11-22-2011, 10:28 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
No reason unless it results in higher shift points and you hit the rev limiter (somethimes this happends.) Good luck
Old 11-22-2011, 08:42 PM
John A. Marker
John A. Marker's Avatar
with 383Vett. Most often the only reason for a tune is due to cam change. You should be fine unless the shift points have changed drastically.
Old 11-24-2011, 01:42 AM
F.G.
F.G.'s Avatar
Thanks guys, its just that I had heard of the 4L60E guys having to get a tune so I was just wondering if us 700R4 guys had to. However I was confused because I thought that the 700R4 was not controlled by the ECM.
Old 11-24-2011, 03:12 AM
Cliff Harris
Cliff Harris's Avatar
On a 700r4 the ECM only controls lockup of the torque converter.
Old 11-24-2011, 10:25 AM
Pete K
Pete K's Avatar
You are correct. 4l60e guys need a tune above 3000 rpm stall.
ECM on a non-electronic trans only controls lock up.
Old 11-25-2011, 10:09 PM
F.G.
F.G.'s Avatar
Nice! Thank you all very much
To Tune after stall install?
Quick Reply: Tune after stall install?
