spring recommendations
I researched the handling set up on the C-4 for 3-mounts and this is what I cane up with .Put the biggest stuff in the front you can find the back is the problem and is the sway bar if too stiff will not let the back of the car move and bite .. The rear has to move to work right,, fine line too soft too stiff ..This is what I came up with all NOS parts..and love it can run turn for turn with any stock C-5 C-6 can't pass don't have the power I can push them in the turns..Track vett sunday vett club vett just very good alaround ride..Rides a little stiff..It's a 86 style Z-51 set up 1 1/8 F.sway bar Front spring FHA F/RATE 93.1 Rear Spring NYC R/RATE 57.2 .. No poly on rear bar will not let it work right. Had Biletein rebuild the shocks to mach Sup. The alignment a cross between road race and street works great for what I do.. GM knew what they wer doing when they build this C-4 just have to put right parts in right place..This is not my set up I didn't come up with it ..Guys that have raced these for years cane up with it.. I just called and asked lot's how to and what to do stuff.. It's not fancy stuff I can go into a turn at any speed if the tires will hold I come out on other side.. What I like best it stays were I point it, stays in track... I put lot's into this just trying to help good luck..
so 1 1/8" is a 28.5/28.6mm bar? what year and suspension was that off?
What does this mean "Had Biletein rebuild the shocks to mach Sup."
I realize you typed it out fast, but some clarifications would help those of us searching for a decent track setup without going to coilovers.
TIA!
This sounds similar to the setup I am going to run, obviously haven't run it yet and also have pst bushings all around.
Sway: 30/26
Spring: BMB (84-87) or (88+) FHB/NYU
Rates: 102 or 115.5 / 57.2
There was never a 28 or 28.5mm bar offered by GM...
http://www.corvetteactioncenter.com/...usp_chart.html
Sway: 30/26
Just fyi the vbp sport springs are the same rates as the z07. And ecklers sells a set that are the same rates for the z51. But that fit the latter models. Keep in mind the c4 should run b stock by scca rules and if the z51 was not available in your year you cannot use those rates only the z07 rates
Let me get this straight - you were able to use a z51 spring from an 84 on the front? or just an FHA spring from an 88 and up?
TIA!
TIA!
Forgot Biletein will rebuild old shocks .You have to tell them what you got and how you going to ues the vett ...There on line look them up...Like I said it's been a year I have the info somewere ..Not hard to do.. The price not too bad for the rebuild... and work great..it's a combo thing can't just but parts on and have a good handleing ride have to work at it ..The parts have to work together..Lot's people just give me the big stuff and think I got it or lesion to the young sales guy..NOT THE DEAL ...
TIA!
TIA!
Sway: 30/26
Sway: 30/26
yeah, the z51 is 115 while the z07 is 93, the vbp sport is also 93, and since the OEM springs are no longer available, most clubs should be okay with using the vbp as the rates are the same as the z07 so there really would be no performance advantage. Personally this is the setup I will be using I will be buying in the next month. I would reccomend doing the front and rear matching models. In other words if you go with the vbp in the rear go with their mathing in the front also. I would also reccomend waiting on the shock rebuild until you install the springs, keep in mind with a harder spring you might actually want a more compliant shock with a slightly different rebound setting.
I went back and loked at the chart..If you can olny go stock what 92 ZO-7 set up looks like a good one ..The alinement is the key with the C-4 may have to try two or three times to find witch one it likes .Mine gets a little off from what it likes and will not handle as good have to keep it right took me three times to find the right one for the Sup... you know when you get it ..Drives very good half a turn here and there dig deal with the C-4..
I was thinking a heavier front spring might be helpful. I can go aftermarket without changing classes, but coilovers are not an option because it starts throwing me in unlimimited classes. They are only governed by adjusted hp/wt formulas and then the cost is thru the roof to be competitive.
I went back and looked at the chart I was off ..It'd been a year I thinking that 115.5 is very big and is ok ..Guys told me can't go too big in front .You should have a good set up.... a 28mm ???? I went in in. with the bar in front and mm in the back that's how VBP has them listed ..Just read what i said about the rear it works and good luck...
Yeah, I think the setup will be good. I have custom valved bilsteins for spring rates that are pretty similar (a little stiffer in the rear.) I ran it last year on stock springs as that was all I had and didn't have time to change it. It didn't do too bad, but it needed more!
Luckily mine came with the Z07 option, so I have those springs and bars. I'm just not having good results with the revalved bilstien shocks I purchased several years ago. The main issue is the most I can get is 0, thats right zero front camber. I've got the adjustable lower bushings to install this winter and that should get me a little camber, I'd love -3 but anything around -2 is workable. Of course I'll need to learn to drive the car all over again
#34
I got -2 on the left side and -2.3 on the right with no shims and I don't even have offset bushings. The wheels tucked up under the fenders quite a bit and it looks mean. I didn't do it for looks but for road courses. I can tell you more is better because the tires are still wearing on the outside couple inches and the tires need to be flipped on the wheels. With this setup using 1990 Z51 springs that are lowered and 32/26 sway bars/camber brace/Nitto NT01 tires I can run a 2:43 at Road America with stock pads and brake cooling ducts. I brake very early because I don't trust them and never upgraded. I know I could be in the 2:3X's with good brakes. As it is now I am passing cars with over 100hp on me just because I can take corners that much faster with confidence. People with faster cars would come up to me and ask what they heck I did to my car and for the most part it's a stock LT4. Now I'm going to sell the car and will have the sways/camber brace for sale if you want them after I get them pulled in the next week.
#36
I didn't read the whole thread - but let me give my 2cents on the springs.. IMO what made the 84 Z51 the stiffest car was the Spring and Shock COMBO.....
I replaced my 85 NON Z51 springs with 84 Z51 and was very supprised at the little difference they made - other than making my shocks feel like they weren't able to compliment the springs.
I have a solid 30mm front bar and stock rear - I already cornered pretty flat but wanted to control Accell/Decell motions a little better.
