Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-03-2011, 08:25 PM   #1
miamitaz13
CF Member
Support Corvetteforum!
miamitaz13's Avatar
Default code 43
i got a code 43 on a 92.What should i be looking at
miamitaz13 is offline   Reply With Quote
Old 11-04-2011, 04:28 AM   #2
toptechx6
CF Senior Member
toptechx6's Avatar
Quote:
Originally Posted by miamitaz13 View Post
i got a code 43 on a 92.what should i be looking at
Book #2 FSM.
toptechx6 is offline   Reply With Quote
Old 11-04-2011, 07:52 AM   #3
bjm206
Junior Member
bjm206's Avatar
Code 43 is an ESC fault that is tied to the knock sensors and related electrical circuitry.
bjm206 is offline   Reply With Quote
Old 11-04-2011, 08:02 AM   #4
jaa1992
CF Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
James Anderson
Send a message via MSN to jaa1992
Quote:
You need book2 of the FSM to troubleshoot.
Basically check knock sensor wiring and the knock sensors.
jaa1992 is offline   Reply With Quote
Old 11-05-2011, 01:01 AM   #5
Cliff Harris
CF Senior Member
Cliff Harris's Avatar
There are two parts to this error, startup and running. In general, the ECM is VERY unsophisticated with the error checking and you need either a solid short or open to set a code. The knock sensor is basically a microphone that listens for the knocks. The knock signal is amplified and filtered by the ESC module and the module sends a signal to the ECM when it detects a knock.
When you first start cranking, the ECM adds 20 degrees of advance to force the knock detector and ESC module to work. It passes this part of the test if it sees 2 knock counts, which proves that the knock sensor and ESC module are working. I can hear the knocks when the engine first starts, kind of a rattling sound. I recorded two knock counts on my car during startup. Here's a pic:
http://home.earthlink.net/~cliff_har...eforms.html#B7
The ECM also looks at the ESC signal while the engine is running. It sets a Code 43 if the ESC signal is low for longer than 0.0143 seconds (like a short to ground or the output of the ESC module is stuck low -- it should be high except when it sees a knock).
Unfortunately there is no way to tell which part of the test failed without using a scanner.
Cliff Harris is offline   Reply With Quote
Reload this Page code 43
Tags
43, code, corvette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
