engine push start button
hello,
recently I was looking on ebay at a keyless entry w/push start button, anybody is using a such thing ? is it hard to integrate it ?
I just want to get rid of the key ...
I put one on my 1989 Silverado. It took about 4 hours. I was tired of going out in the winter to start the truck to warm it up. The kit also gave me auto door locks, a parking lot beep and flash and could have opened the trunk if I had one.
All the wires you'll need are external to the steering column, under the dash on a Vette. (except the door locks and trunk) The kit I got told me where every wire was located, it color and how to attach it. Some of the wires you will cut yours and splice both ends into the new harness for the remote start. Others will be paralleled with existing wire.
It's a really neat device that's not too hard to install.....based on your experience level.
This company includes vehicle specific wiring instructions. It will say something like, "on you 19xx Corvette on the right side of the steering column, under the dash, locate the red wire in the harness from the steering wheel."
I mean all their instructions are made just for your car. I've installed three of these and everyone was right on with the wiring. So simple a caveman could do it.
http://www.autoalarmpro.com/remote_starter_w_keyless
They also have a really cool but pricey option where you can use your smartphone to do all the same things the remote does. You just touch the App button, touch Car-link and the screen comes up with Lock/unlock/start/trunk release/ icons. How cool is that. Give you bragging rights at the cruise-in.
This thread is one system that I installed. I recommend you stay away from this one. But it has been in for more than a year now and has been working ok.
The Push-to-start is what makes it difficult with VATs. That and taking the column apart. But a general after market system is difficult enough on a vette.
I was thinking at something from Dowontech like st800 or st960 ... Flame Red thanks, hope your thread will help me intall a keyless/push-to-start system ...
One of the things with the StarDrive that made it difficult is that you need a lead that signals when the alarm was disarmed. This is needed to tell the factory alarm system to disarm. StarDrive did not have this and so I had to rig up extra relays to figure it out. Real PITA and it is not perfect. I would be nice if they had the schematics for this system. I would like to look at them and make sure all the leads I would need are present.
Found it:
I wonder what the range is for the st960? The Stardrive has less than 10 foot range and will lock and unlock as you walk around the car (which really, really sucks).
