MAT Sensor - Funny Stuff!
While looking at the 1227165 BUA code that's in my car, I discovered that the MAT sensor is ONLY used to turn on the EGR.
So all you guys who relocated your MAT sensors in the hope of getting more performance have changed the EGR enable characteristics a tiny amount. EGR gets enabled if the MAT temperature is higher than -17.5 deg C, which is 0.5 deg F.
C4ProjectCar (10-03-2020)
Fuel, spark and everything else is controlled by the CTS - Coolant Temperature Sensor.
I'm looking at the CODE. No guesses. No rumors. No "I read somewhere...". No "Somebody told me...".
If you want to check it out, look here:
http://home.earthlink.net/~cliff_har...5/BUA/BUA.html
The EGR code in question is at LDEF0, using the MAT at L0060. L0060 is not used ANYWHERE else:
Code:
LDEF0: LDAA L0060 ; Manifold Air Temperature (inverted ADC voltage) CMPA LC23A ; disable EGR if MAT < (30 = -17.5°C = 0.5°F) BCS LDF45 ; BR if < -17.5°C = 0.5°F (disable EGR) ; ... else LDD LC238 ; Enable EGR if TPS > (A = 5 = 1.95%, B = 8 = 3.13%)
Code:
Possible to remove the SES light also? I'm assuming it would flash if the MAT were disconnected.
Doesn't the engine need to have some idea of how hot/cold the air charge is? 40 degree air is more dense than 100 degree air, and requires more fuel to achieve the correct AFR. The engine can't determine the outside air temperature by how hot/cold the coolant is.
Not saying what you have found is wrong/incorrect, but I am interested in how the engine would operate without knowing the temp of the air. I know when my MAT failed, it always read -40C when datalogging
Later years, the intake temp was used for more than EGR. I get a laugh when people move the MAT on the early C4's.
Of course, O2 data (on the backside) constantly monitors and correct what the ECM thinks it needs to do.
Sorry to bust your bubble , but MAT is used along with MAP or MAF , ECT , O2S , and TPS to determine the correct fuel injector pulse width to maintain proper engine operation under varying conditions ... it plays a minor role however , and any performance benefit derived from its relocation would be miniscule at best ..........
Yea, but it is in an inacessible place that is very hot. I was nice enough to put it in a place that was much cooler. Now I can see it every time I open the hood.
Light years ahead of most others yet today.
Many secrets yet to be cracked open & explanation in full unfolded.
Keep in mind that I'm looking at the '86 code, specifically BUA 1728, which is automatic trans with 3.07 rear gear. My car is an early '86 (I got it 12-24-85) and it actually has BUA 9340 code in it. One of these days I'll do a .bin compare and find out what the differences are between the 9340 & 1728.
I don't know if the MAT reading was used for more things in later years (or when the changes were made).
The 1227165 ECM was used from '86 through '89, but obviously there were code changes along the way, especially for '89, where there were major changes.
Never could stop those things though. They've got a life of their own now!
Pretty funny, eh?
I'm sorry!
Not that funny?
I'll shut up now!
Gregg, It is Labor Day, so I guess your allowed to Drink.............Then post.......WW
The $6E code does make more use of the MAT sensor than either $32 or $32B. It is used optionally in a few places instead of coolant temperature FWIW.
Start up enrichment
crank fueling pw
idle speed time out IAC steps vs coolant or MAT
Start up enrichment
crank fueling pw
