Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C6 Corvette: How to Reset Your Oil Light
Step by step instructions for do-it-yourselfers..
How to Reset The 90-96 Change Oil Light
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_marine_corp.png)
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/StJude10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Be sure to reset the monitor when your oil is changed,
even if the CHANGE OIL light didn’t come on. If you
don’t reset the monitori,t won’t work correctly. Follow
these steps:
1. Turn the key to RUN, but don’t start the engine.
2. Press ENG MET on the Trip Monitor. Then, within
five seconds, press it again.
3. Witbin five seconds, press and hold GAUGES on the
Trip’Monitor. The CHANGE OIL light should flash.
4. Hold the GAUGES button until the CHANGE OIL
light stops flashing and goes out. This should take
about ten seconds.
When the light goes out, the monitor is reset. If the
monitor doesn’t reset, turn the ignition off, then try
again.
SUPER...actually better than super ![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
And with music....WOW![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
these steps:
about ten seconds.
again.
these steps:
about ten seconds.
again.
![](/forums/images/ranks/1k-2k.gif)
I need to do that as I did not reset the last time because I forgot the procedure. I do have a question, can the length of time be changed? I just swithched to AMS Oil and extended filterfor upto 25,000 mile's between change whic is more than what I would drive in a year, so I plan changing just once a year. Next spring when I change it I want to send a sample in to see how good it is and any problems. Thought there might be something that could be changed on the computer, otherwise will have to reset it every time it pops up.
![](/forums/images/ranks/2k-3k.gif)
No, the length of time cannot be changed.
The PCM takes into account: Oil temperature and engine revolutions.
The "Change oil" light should go on somewhere between 6,000 and 7,500 miles. Depending, of course, on your particular use.
SAVE the WAVE!
SAVE the WAVE!
![See Ya!](https://www.corvetteforum.com/forums/images/smilies/seeya.gif)
i just got my oil changed and the tech didn't know how to reset the light. Bless his heart. the instrutions were perfect but i didn't scroll down far enough, lol i have a 90 zr1. this site is amazing, thank you all for all your posts.
dt
dt
I have tried many, many times to reset my oil light, and nothing has worked. I still have the light on. The buttons seem to work fine when pressed, so I don’t think it's a bad button issue. Still looking for answers.
![](/forums/images/ranks/3k-4k.gif)
Funny how the little victory's in life tend to please me almost as much as the significant ones. Like the time I was ... between jobs ... for a time. I was living in an aircraft hangar for $250 a month while repairing my truck. They finally caught me and gave me my walking papers; but I don't know ... it felt like I was having fun. Look at me now. Thank you, Lord! And thanks friend, for the reset instructions.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
manual ... they make a manual?? hee .. hee ... just kidding! That would have been an option ... if I had actually ever remembered the light was on before getting in and getting it powered up.
