courtesy lights will not go off
7th Gear
thanks for any help in advance!
i have a 92 cortesy lights will not turn off unless i pull the fuse,i thought maybe one of the door switches could be bad .they have good spring to them
I'd start with the switches, check them, make sure they have good ground, check the hatch switch too. Oh, wait, first, are you sure you didn't bump the switch to turn them on all the time? On a 92 I think it is having the dimmer slide all the way up.
