Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-25-2011, 02:35 PM   #1
pipe
CF Senior Member
Send a message via AIM to pipe
Default C4 windshield replacement?
I talked with 3 different glass install company's only one said they need to replace a moulding or weatherstrip. The one that wants to replace the molding wants $800 the others $ 400 whats the deal with the molding or strip for the extra $ 400 and what if I don't get the job with the molding done. Will it leak? THANKS Pipe
pipe is offline   Reply With Quote
Old 08-25-2011, 02:46 PM   #2
3D87C4
CF Senior Member
3D87C4's Avatar
I got low bids with no mention of molding etc. and one bid, comparable to your's, that included it. I went with the higher bid---if they don't need it they won't charge for it. (They did need it in my case.) I'd rather work with someone who documents the full job than be surprised, or worse, end up with someone who doesn't know what's needed & botches the job.
P.S. I make no claim to being smart with my money...
3D87C4 is offline   Reply With Quote
Old 08-25-2011, 06:56 PM   #3
mfi
CF Senior Member
mfi's Avatar
They replaced everything on mine and it has never leaked..insurance job so I got the best stuff possible..
mfi is offline   Reply With Quote
Old 08-25-2011, 08:07 PM   #4
mwilson
CF Member
mwilson's Avatar
be sure and call around. just had mine replaced. 1994. 240.00. im in indiana. not sure if that makes any difference
mwilson is offline   Reply With Quote
Old 08-25-2011, 08:26 PM   #5
Sparkytfl
CF Senior Member
Sparkytfl's Avatar
profile.php?id=1405987169
I got mine done for about 210 after tax from the shop thats voted best in the city every year. They must do a flat labor fee because I doubt they made much money when it took them seven hours to do.
Sparkytfl is offline   Reply With Quote
Old 08-25-2011, 10:03 PM   #6
mackeyred96
CF Senior Member
Cruise-In VI Veteran
Cruise-In VII Veteran
mackeyred96's Avatar
Location: NCM Drag Racing coordinator, Spring Hill, Tennessee
john mackey
i had safe lite come to the house and change mine with new moldings for about $300. I can't see how you could use the old molding...
mackeyred96 is offline   Reply With Quote
Old 08-26-2011, 07:21 AM   #7
mfi
CF Senior Member
mfi's Avatar
They charged the ins co......2200.00 for the job..replaced the side window as well...but still
Old 08-26-2011, 08:00 AM   #8
Joe C
CF Senior Member
Joe C's Avatar
had the windshields replaced on both my 85 and 90 - both times, they did not replace the molding. on the 85, the installer said it would have been easier to replace the molding. as i recall, the installer charged the insurance company a tad over $300. i have "zero" deductible, so my cost was, well, you do the math -
Joe C is offline   Reply With Quote
Old 08-26-2011, 05:04 PM   #9
RLG
CF Senior Member
the weatherstrip is glued in at the factory, it usually needs to be replaced.
RLG is offline   Reply With Quote
Old 08-26-2011, 05:04 PM   #10
RLG
CF Senior Member
Default Safelite
Quote:
Thankyou!!
Old 08-27-2011, 10:11 PM   #11
pipe
CF Senior Member
Thanks for all the reply's I gotta check into this a little more. I have a new weatherstrip for on the bottom of the windshield. Pipe
Old 08-27-2011, 11:06 PM   #12
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
greggpennington
The piece on the bottom of the ws isn't really considered weatherstrip. More of a trim piece.
Windshields have both a weatherstrip (aka A-pillar weatherstrip) and a molding. The molding can easily be removed and reused -- if your car hasn't seen a lot of moisture. But, that piece can corrode/rust. Some companies use an aftermarket trim piece that's cheap...about $50 IIRC. Haven't seen one, so I don't know if the quality is good/bad. It's basically a trim piece, so it just has to look even. Probably not that hard.
From dealers, that trim piece was astronomical and some companies charge accordingly -- especially if an insurance claim. I wouldn't be surprised if the old one was reused and the price was bumped just to get more profit.
I just got my 2nd windshield for my 89. I replaced the WS on the first go around. It could have been reused because it wasn't glued with the 1st replacement. It sits in a double-lipped channel and doesn't require gluing. The trim piece was reused both times.
Be aware that companies will often match low-bids from other competitors. Plan on $240-$250 if everything can be reused. If you need new WS, installation becomes free with the WS swap. Plan accordingly.
GREGGPENN is offline   Reply With Quote
Old 08-28-2011, 11:25 AM   #13
delmarva dave
Junior Member
I have been in the auto glass business for 31 years and work on lots of classic cars .I
would NEVER replace a windshield in a c4 corvette without replacing the weathestrip.there is an aftermarket one and the gm one they are bothe ok.you will regret it it if you dont replace it!!!!!!!
delmarva dave is offline   Reply With Quote
Old 08-28-2011, 04:09 PM   #14
3D87C4
CF Senior Member
3D87C4's Avatar
Quote:
Glued in with a vengance! When mine was being replaced there was so much glue they asked whether the windshield had been replaced before. (It hadn't been.)
Old 08-28-2011, 04:25 PM   #15
delmarva dave
Junior Member
Default windshield replacement
Those weatherstrips are so glued in from the factory,it is terrible,i just replaced my 92 windshield repainted all my moldings and wipers at same time looks great!
Old 08-28-2011, 06:09 PM   #16
kenv
CF Senior Member
St. Jude Donor '10
kenv's Avatar
Location: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
When I bought my `87, I got it from a local (now defunct) Chevy dealer. It had a problem with the wiper motor & had to be fixed for inspection. The ASE certified mechanic working on it broke the windshield with a screwdriver. I found out later that the dealer looked all over to try to get a used windshield without luck & finaly had to get a new one & new weatherstrip. The owner was not happy with the mechanic.
__________________
`87 yellow coupe (for fun)
`90 supercharged coupe (for more fun)
"EVERY DAY ABOVE GROUND IS A GOOD ONE"
The only thing that stops me from being rich is the lack of money.
Dogs are not our whole life, but they make our lives whole
kenv is offline   Reply With Quote
Old 08-28-2011, 06:43 PM   #17
PLRX
C4 Owner
St. Jude Donor '09-'10-'11-'12-'13-'14
Support Corvetteforum!
PLRX's Avatar
In San Diego it costs $900. Remember, shortcuts will not get you there faster.
PLRX is offline   Reply With Quote
Old 08-28-2011, 08:21 PM   #18
GREGGPENN
CF Senior Member
GREGGPENN's Avatar
greggpennington
For a windshield that's never been replaced, I absolutely, 100% agree. Even when my 2nd WS hadn't be glued, I swapped out the WS again. That's mostly because I wasn't happy with my first aftermarket piece.
Old 09-25-2011, 09:00 PM   #19
Black Beauty 88
CF Senior Member
Black Beauty 88's Avatar
Are you still in the glass business? My '88 has scratches from the PO running wipers with little/no rubber on them. They aren't bad, but still bother me. I'm in Camden just up the road.
Black Beauty 88 is offline   Reply With Quote
Reload this Page C4 windshield replacement?
Tags
87, 89, auto, c4, ca, corevtte, corvette, forums, glass, moulding, related, replace, replacement, windhsiled, windshield
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
