A set of Brand New Injectors for $150 too good to be true?
It’s seems time for me to replace my injectors in my 91 L98. I am looking to replace them with the stock 22 lb for now. So I have been shopping around and I found this guy on fleabay that has all 8 brand new injectors for under $150. My first reaction was Wha? Wha? What??? He claims they are from a company called “Standard Ignition” with the Part Number FJ47, which is the same P/N as Standard Motor Products but for over $500 on summit. He also claims they are brand new.
Has anyone ever heard of injectors made from “Standard Ignition”?
Are the injectors from “Standard Ignition” the same injectors from Standard Motor Products?
That seems really cheap but I have never heard of the brand “Standard Ignition”. Should I pass this up and just keep shopping around?
FIC is the favorite choice here on C4.
Standard Ignition has been around since the 1940's.
For $150 for a set of L98 fuel injectors on ebay,
they have to be re manufactured too like FIC's replacement L98 set.
Most brand new Or GM NOS injectors run from $90 to $130 + each.
So a set of Remanufactured injectors for the C4 guys makes $$$ sense.
They work pretty good FIC's 99 % of the time for me.
Other 1% is WOT for me on wide open roads.
FIC's do make for easy cold weather & hot weather starts.
No more feathering the gas pedal like before to get your L98 TPI Corvette started up.
go FIC.
if there is anything wrong with something you buy from FIC, it will be fixed.
Getting ahold of people on ebay can be a real pain in the ***. I'd buy the peace of mind for $30
Jon @ FuelInjectorConnection also has some great deals. Some people swear by the Bosch III (rebuilts?) he sells...and say they give a bit better mpg. Others have an issue or two....usually not major. Some get worse mpg. Jon will work with you though.
Look for his GIANT stick thread with compiled information.
i've bought two sets of boschIII's from Jon@FIC - don't second guess - buy from a forum vendor. Jon has great sales and service, and 99 out of 100 forum members swear by FIC.
Supporting Vendor
Here's the facts on this injectors. They are sold by a guy in Texas, they are not fj47 they are Junk I have a set here, for fun ask him if the pn is on the injector, it has part number rin--- can't remember it off the top of my head. I will do a video comparing a real fj47 and this. Watch later. I can sell you brand new fj47 if you want new for 389 and match the set since we stock a few hundred of them
__________________
Supporting Vendor
The problem here is you think you know the business, those are not fj47's so let's compare apples to apples, they are a replacement fir the fj47. I'll prove it to you shortly. Bosch makes the best injectors. Period. A rebuilt quality injector is way better than a new cheepo. I can buy those also for less than 10 bucks each, a real fj47 is way more. After you see my video then you can talk about it. Sam and me go back a long time, but. Parts should be represented for what they truly are. Next thing you will tell me is that the Chinese knockoffs are good also. You have constantly badmouthed us for years. Keep it up it's good for business. If you go back to 09 archived threads you can see that you used to sell injectors. We came in and you got pissed. Over 3000 c4 owners have bought from us, we stand behind everything we sell. You constantly state we sell used injectors, but equally we sell as many new also.
In the hopes to avoid a flame war (interesting as it may be) Ive been thinking about replacing / refurbing the injectors on my stock 91 L98 also.
My symptoms are rough/uneven idle, sometimes it wants to stall, but the IAC will kick in at the last moment and rev the motor. Ive checked for vacuum leaks, dont think I have one, but not confident I did a thorough enough test. Ive tried to set the minimum idle rpm, but I cant the engine to run at that low of rpm, it keeps stalling. Ive replaced EGR (was throwing a code), set the TPS, timing, etc, with no improvement. No current codes.
Heres what I know - in 95 or 96, the previous owner had a dealer replace all the injectors (I have the repair paperwor) for $1000+. I also ohm'ed the injectors about a year ago, both hot and cold, no obvious failures. So I dont *think* I have the original design multecs that are prone to failure.
How much dinero to refurb the ones I have? I would just rather stay with the multecs - dont ask why, my ocd kicks in.
http://www.corvetteinjectors.com/contact.html
Supporting Vendor
Supporting Vendor
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
I've done business with FIC in the past and they were straight up honest with me. I would buy from them again. When it comes to injectors, If they're extremely cheap, be suspicious. Remember, you get what you pay for. FIC is the way to go. Almost 100% of the forum can't be wrong.
P.S: Anyone thinking about bashing FIC or disputing anything posted here, it would be best to do it through PM's or offine. I'm ready to hand out extended vacations to anyone who turns this thread into a pissing match.
Supporting Vendor
video as promised
here is the video. it speaks for itself. We are not trying to badmouth any compitition. All we want to do is keep you informed on the parts that are being offered for your car. In the world of autoparts you never know what or from where a part comes from. A seller can basically say anyyhing and its up to us to do the research. The OP asked a simple question. "is it true that you can buy a FJ47 set of 8 for $150.00 Brand new." well all I can tell you is that the "new" part is true. The "Brand" part is questionable. Its up to you to go to Standard parts cat. and see what a FJ47 looks like. If it looks different than how can it be the same. Here is the link: http://www.standardbrand.com/Online%...g/Content.aspx
Watch the Video.
Watch the Video.
I bought NEW Bosch Design III fuel injectors from Jon in June of 2009.
You can read about my experience here: http://forums.corvetteforum.com/c4-t...long-read.html
With over forty (40) years of experience in the auto & truck industry I can say the following:
Jon, is hands down, the BEST vendor I have ever had the pleasure of dealing with or knowing.
What Jon says is true.
His customer service is stellar.
He will talk to you at any time to help walk you through the installation of any injectors you purchase.
Today, my WAVE goes out to Jon:
