What U-Joints Would You Use?
What u-joints is everyone running? I need to replace all six of mine and while I’m at it I have a new set of Bilsetins to put in.
I have them on my to-buy list, Spicer all the way !
I Think this is what you need : (PLEASE CORRECT ME IF IM WRONG)
$17 x 2
Spicer 5-1310x
$28.95 x 4
Spicer 5-1350x
Solid u-joints,do not get ones with grease fittings.
17 x 2
http://www.dennysdriveshaft.com/p456...ance_free.html
28.95 x 4
http://www.dennysdriveshaft.com/p460...e_u_joint.html
$17 x 2
Spicer 5-1310x
$28.95 x 4
Spicer 5-1350x
17 x 2
28.95 x 4
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,106 Likes
One can't do any better. The seals on the spicer work better than some out there so water does not enter and rust. Also, the amount of lube is measured so don't try to add any during assemble. You might try to keep each cap in order to assure same position and lube amount. I had to find a truck supplier to find mine here in Nashville, Tn.
Spicer all the way..No grease fittings weak point in the fitting hole might crack.. I replaced mine on my 96 135,000 miles, My vette doc. said all but 1-2 looked good I think he said GM used Spicer when new ..I put all in takes some time to do right 96 ,, Drives 10 times better, tight ..If you do it get car up were you can get to it and no short cuts and just takes time and mine just better ride, it's hard to put a finger on it just better ..Good luck....
I was told by Paul the owner of Northside Corvette in Cedar Minnesota that you have to replace the caps when you replace u-joints. Ant truth to that?
I doubt you HAVE to replace them. I didn't know it was an option when I did the u-joints on my half-shafts. I took hours cleaning those suckers up - If I had known I would have replaced them.
If you are talking the caps that ride on the needle bearings - all the new u-joints have them.
I didn't on mine ..But just as I was takeing mine off the rack I seen these very nice ones for sale I would have liked to but on.. If it to do over I think I would . Too much work to go back now..If it makes you feel better do..Look at them and if look ok?? I have pun in new ones sometimes not.. If big power yes...It'd not a have too thing..
if you are considering higher HP, may want to just go with this step that includes the u-joints.:
http://www.dennysdriveshaft.com/p127..._inch__19.html
These are 4 inch diameter aluminum half-shafts that replace your stock 3.5" aluminum half shafts.
Better than the steel halfshafts they make (less mass).
Not sure if they will clear rear coil-overs though if you have that mod.
They also include the best spicer 1350 (non grease fitting) u joint.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
I'd like to know if anyone has actually broken one.
I mean someone that drives their Vette mostly on the street.
Having the ability to give these a shot of grease once in a while is reassuring.
I for one have Spicers but when the time comes to replace these, will Spicers be available anymore?
I was referring to the straps.
Those are some pretty fine half shafts but probably a little over kill for my daily driver but is would help the appearance of the under carriage.
It appears Spicers is the way to go.
Is Summit Racing’s size descriptions correct on their site? There are discrepancies in the sizes they show versus Calderone’s links.
I have done two C4's now. The spicers just slid in so easy with minimal effort from a press, hammer, or whatever. the half shafts I did with the imported cheapies were an ordeal that took a long time to press in. They probably ruined the yokes as the properly sized ones would fit loose now.
$17 x 2
Spicer 5-1310x
$28.95 x 4
Spicer 5-1350x
17 x 2
28.95 x 4
$17 x 2
Spicer 5-1310x
$28.95 x 4
Spicer 5-1350x
17 x 2
28.95 x 4
Please measure from the exact center of the u-joint cap diameters at each end of the shaft for an accurate center to center overall length dimension to order any half shaft. Please measure the universal joint cap diameter carefully. The 1330 series (usually found on early eighty’s aluminum half shafts) will have a 1 1/16th inch (1.062) u-joint cap diameter and the 1350 series (usually found on all years steel or aluminum) will have a 1 3/16th inch (1.187) u-joint cap diameter.
Do we know for sure that the 1350s fit an '87?
They come like they come ..I never seen any coating on them ..I guess they had something on them the ones off my 96 were 14 years old and looked very good @140,000 miles.. Just take time installing and ride... I had a clunk in my rear and the vett had one in the rear also ..I was hopeing U-Joint not the rear so changed the rear fluid and all U-Joints stoped the sound and I don't know what it was ..No sound out the back now ..The spicer Joints were 14 years old and looked new when I got them off..
Right here..Best\Strongest U-Joint you can buy.
http://www.neapco.com/nA-aftermarket-products.php
Yes U-joints must be coated for aluminum half shaft sides and Neapco's are and HP ratings are way higher than spicers.
