How to disassemble cluster for 91?
The dash LCD display was intermittantly working. I have the cluster out of the car and would like to try to repair it. Based on some old posts, i will start by looking at the lcd connector. My problem is that I can figure out how to take the cluster apart. I removed the thin black plastic back cover and screws holding the pcb down. But the pcb doesnt seem to easily be removed from the white housing. I dont want to flex the board too much and crack a solder joint. I also tried the front, I removed the clear plastic curved cover bat still cant see how to expose the inside. I checked the forum search and couldnt find specific instructions.
thanks,
howdo
thanks,
howdo
Good luck!
