Manual control of main cooling fan
Just double checking - if I splice into the green-white wire leading to the coolant temperature sensor and feed that to a switch that is grounded I can run my main cooling fan manually but not affect the normal operation of the main cooling ?
Want to use this between autoslalom runs in a co-driven car to help cool it.
Thanks!
Thanks!
Just like your aux fan thread, tap into the dark green/white wire at main fan relay.(inner fender beside battery)
http://forums.corvetteforum.com/1578110840-post3.html
Thanks!
Thanks!
Agent 84 has good info to energize the fan relay.
But without knowing what year car you have will make a difference in the information. C4s span 10 years and things are done different in the different years. Please state you year and best fill the profile out.
Thanks!
Thanks!
