Missing Question
Old 11-01-2013, 05:17 PM
glava2876
glava2876's Avatar
Default Missing Question
My car (84 4+3)has been running great all summer after having the ported intake and 1:6 roller tip rockers installed in the spring -well except when the fuel pump died.
I have been trying to drive it more before winter gets here and it has started missing under hard acceleration above 4kRPMs. It seems fine under a little lighter acceleration and easily goes just above 5k when shifting.
I had replaced the cap/ rotor plugs and wires just after I bought the car about 4 years and 10kmiles ago (Bought with 84k miles & now have 94kmiles).
The fuel filter was replaced last winter and the fuel pump was just replaced a couple of months ago.
Figured I should look at the condition of the plugs and cap/ rotor first since they were just standard NAPA replacements.
Is there anything else that I should look at this point -could the wires need replacing?
Old 11-01-2013, 05:43 PM
don hall
don hall's Avatar
One item not mentioned in your replacement list is injectors.
May not be your specific cause, but a faulty injector could result
in a 'miss' under heavy acceleration.
And, with engine revving, in the dark, check the plug wires for any spark 'jump'.
Also, check the manifold vacuum:
http://forums.corvetteforum.com/c4-t...uidelines.html
Quick Reply: Missing Question
